Drivetrain R56 custom tuning by RMW
#453
For anyone concerned about drivability and a neutral opinion (I have never had any association with Jan or even met or talked with him) etc.....I have driven Thumper's car. I have a stock 2009 Cooper S and Stock 2009 JCW Cpe and an Ex- Bimmerworld SWC 3 series. His car definitely pulls hard in all gears with little to no torque steer. Power delivery is very smooth and linear. There is no turbo peeking or hard ramp up often found on many aggressive tunes where they bring too much boost or timing in too quickly. I would say it is NOT an aggressive tune which may cause future problems but rather a great safe tune that will allow for many miles of enjoyment. I too however am curious to see A/F #’s to determine if I will put it on our MINI’s. I would say Thumper’s car feels about as quick as the JCW. Next time he is in town we are going to run the two cars side by side for comparison.
As a side note piggy back ecu's and "boost boxes" are not a good idea as they increase boost while relying on the stock ecu to compensate often for the timing, injector timing, and fuel flow. Often times you get a very lean condition somewhere in the maps which over time is what gives you a "blown motor" often caused due to piston hot spotting= holes in your pistons and or pistons disintegrating= BOOM. FYI this is not directed at anyone, just background information for those newb's looking for more info why reflashing an ecu is better than going the piggyback route. 9 out of 10 times a reflash is safer as a good tuner will play with all of the aspects of a map or maps to ensure safety.
Jan do you have any capabilities to tune OBD1 BMW ECU’s? We just built a new race motor for the race car and need to get it tuned so it will run safely. Can’t find anyone here in AZ that I would trust.
#454
#460
per the louisville thread: https://www.northamericanmotoring.co...isville-8.html
Today, 04:18 PM
Uncl3 vbmenu_register("postmenu_2794793", true);
Had a full JCW R56 pull 222hp and 250 torque.
Today, 04:18 PM
#461
Just walked in now (11:10pm) I left at 4am and got to Louisville at 11am. My scheduled dyno run was suppose to be at 6pm.
Brian (I didn't catch his screenname but he had an '08 Clubbie) let me take his spot so I could make it back tonight. THANKS BRIAN!!!
I got on the dyno and didn't get a chance to see a baseline run. Jan wasn't sure if my car would take the tune he had and by the time he had it on, we decided just to go for it.
Halfway through the tune, the hotside tube came apart (long story) so I put it back together. At the end of the tune, it came apart again so I had to take it off the dyno and therefore didn't get a chance to do a baseline run (Jan was going to install the stock tune back in)
Jan actually cranked a little more out of it but felt it would be safer at these numbers.
Also, Jan wasn't totally pleased with the results but because of time restraints, he did what he could.
I want to thank Jan and Billy, the owner of the shop. Everyone was patient and helpful and I especially want to thank Brian. If you decide to paint your rear clubbie panels to match your car, I will do them for free. Just let me know.
I will scan and post a graph tomorrow. I never really made it to bed last night before I left at 4am so I've been up 42 and a half hours.
Thanks everyone.
Mark
PS. I still haven't really nailed hit because I didn't want the tube to blow off again. I will get another tube soon. Just for the record, just merely stepping on the gas at 75mph, I can feel it pull.
PSS. Ever since I got the full exhaust and downpipe, my mileage has gone up 2-3mpg. Didn't change after the tune but sure made the exhaust louder.
Here is the graph. It's actually at 221.1 and just shy of 250 tq at it's peak and for some reason, Jan says all JCW go up, dip and back up... not sure why but anyway, here it is.
Not quite what I had hoped for graph-wise, not numbers wise but nonetheless....
Thanks everyone.
Mark
#462
#463
#465
Shane,
The car only has a Forge intercooler, DDM CAI, Exhaust Depot downpipe and full exhaust and ED's cold side tube.
The hotside tube was a concoction of an Exhaust Depot hotside tube and an Alta hotside tube. What happened is I bought the ED hotside tube from a friend who never used it.
It didn't fit worth a damn (as opposed to the perfection that the rest of the exhaust is made with) so I cut it in half. I then cut my Alta and used the upper half of it.
It was temporary until I get an NM engr'ing hotside tube in. Unfortunately because I cut the hotside tube in half, it no longer had a "flange" for the upper Alta to stay on.
It was my fault, it was a homemade remedy because by the time I realized it didn't fit, I was screwed. It was the night before I was to go to the dyno so....
Anyway, that's it, not much really.
Mark
#466
#467
The reason I'm changing it is two-fold.
1) I don't want to take that chance.
2) Because of the shape of the setup now, I felt it catching on the shifter linkage when going into 5th or 6th.
Mark
#468
Thanks everyone.
Mark
Thanks everyone.
Mark
#470
DAMN man... that really sucks. I mean, great numbers for you but if I'm at 250 tq with a JCW AND intercooler AND CAI AND downpipe AND full exhaust AND you're in an automatic, how in the hell did you pull only 20 less tq than mine?
Either....
a) Milltek's exhaust is better than everyone knows.
b) you've got a freak.
c) mods don't make a difference.
d) JCW don't make a difference.
e) I need another tune.
f) Mine is a POS.
Hmmmmmm, I wonder...lol.
Glad you turned the numbers you turned but in retrospect, for another 20 ft lbs of tq, why spend an add'l 6-8K in money.
Either....
f) Mine is a POS.
#471
Mark, my R56 pulls 205WHP and 238WTQ with a DDM CAI on a DynoJet.
Popular belief is some dynos report low and some high, but it is all about repeatability on the same dyno. There are some old thread here on NAM about the different results on each type of Dyno.
It is how it performs on the track and 1/4 mile if your into the 1/4 mile stuff.
If your happy and can feel it in the backside, then good results.
If you want to drive out to Colorado for a DynoJet pull, let me know. You can stay in my guest room.
Don
Don
#472
Don
Don
#473
Either....
f) Mine is a POS.
Either....
f) Mine is a POS.
I spent money like you did and here I am still spending, swapping parts to get the best combination. I have a JCW air intake (from the tuning kit) and Alta foam filter on order to see if that works out better
The tune should be able to compensate to get more out of everything but maybe bigger fuel injectors are needed as well? I am eventually going to get the tune and these will be questions I ask RMW beforehand.
#474
Well, I did ask Jan if he had a tune for the JCW and I was assured that he had one. (which he did)
After 2 hours on the dyno, (the hotside tube came off twice... once during that 2 hour period and once at the end)
I'm not real thrilled with the outcome of this tune. It's noticeable but there are guys running 230-240 wtq with stock JCW.
Guess I'll have to wait until someone has a better grasp on the JCW.
My mods aren't that extensive. DDM CAI, full exhaust and Forge intercooler.
I'm not real thrilled with the numbers.
Sooner or later a tune will be available for the JCW cause for 725 bucks, (that was after Jan deducted 100 bucks because he wasn't happy with it either) it wasn't worth the money.
Mark
EDIT: I should make note that I'm not totally thrilled with the results only because I was expecting more.... not because I am unhappy with Jan's tuning. If someone else tuned it and I got much better results, then I would have a problem with his tune. I was just expecting better results and the final numbers were disappointing. Perhaps I can get Jan to spend some time tuning it when he's not pushed for time.
Mark
#475
In my opinion, your numbers aren't as impressive to you as they should be for the following reasons:
-The JCW stuff probably WORKS. You changed the full exhaust and intake, which in my opinion, JCW actually did it right this time around. I'm convinced the JCW intake is the best way to go. And looks like the exhaust isn't so bad either. Changing on all this stuff on a JCW doesn't make sense, cuz the JCW is basically an already modded version of the Cooper S. So you're just changing from one aftermarket part to another essentially. And the only thing I see remotely helping you is your aftermarket IC, and with that...I have heard not such good things about the Forge.
-The JCW is already maxed out, so the gains are going to be less. A lot of the gains in a JCW over a stock S are probably in the ECU, along with the above parts. So it makes sense that you're not seeing much higher numbers than a lot of the other "stock" cars. Remember, the JCW has the same engine as the Cooper S...sure some of the internals are forged but that is not going to give you more power.
It's a shame you don't like the tune...you're the only one that I've heard of, everyone else that I have spoken with that has it is ecstatic about it, myself included. However, you are the only one with a JCW...JCW's are already fast as it is. Your gains are not going to be proportional to the gains everyone else is seeing sadly.
