Drivetrain Anyone upgraded from the stock LSD
You left out the OS Giken LSD on the list. So far I'm VERY impressed with mine. Sure helps the car produce some good lap times. No clunking in tight turns (like you normally get with a clutch type diff). Significantly reduced on throttle understeer out of corners compared to the OE diff. So far very pleased.
this and the Cusco are the best out there for the money.
OS Giken is probably the best but it's also the most expensive
You can't go wrong with either of these
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
the times don't lie
![Wink](https://www.northamericanmotoring.com/forums/images/smilies/wink.gif)
Darren.... Post is worthless with out at least 2 of the following 3...
Lap times.
Pictures
Video
J/K, How'd you like Laguna? Could you carry 4 Flat on the Kumhos?
Low Grip and Quaife
After reading more than 40 Quaife/LSD/ATB threads I couldn't find answer to how does Quaife work on low grip surface. I am not worried about lifting inside wheel, but how about snow, ice and gravel surfaces?
1. How much more traction you get with Quaife on wet tarmac when launching out of low speed corner? It's design requires some traction on both wheels to transfer torque.
2. Does Quaife work on snow/ice/gravel covered roads? Does it help with traction or should I consider a clutch type LSD? And yes, I already have winter tires with studs for grip.
3. Can you still left-foot-brake on slippery/loose surface with LSD? Does it effect on handling?
Jan Lat62N
PS. Anyone making long 'short shifter' like those in WTCC, WRC and DTM cars?
Jan Lat62N
Jan Lat62N
Jan Lat62N
Second question what your looking for in those race cars is a sequential gearbox. I haven't heard of one for the mini(but I am still a noob) but I know M7 has something that's is close to one.
http://www.m7tuning.com/parts/produc...roducts_id=123
Interior/Exterior DEPO/Helix Projector Headlights Installed
Alkaidovich
01-30-2021 01:35 AM
07-16-2020 12:54 PM
12-05-2016 06:31 PM
sabjcw
08-14-2015 07:40 AM
