Drivetrain ED Downpipe Heat shield
on
For those of us with the ED downpipe, has anyone reinstalled the lower shield? If so, what did you cut in order to make it fit?
I am scheduled to return from Afghanistan next month and it bothers me that I don't have a lower heat shield. If no one has it installed, are there any problems with heat and such? My wife hasn't driven the MINI too much in the last 6 months so I don't know how hot it has gotten.
Thanks.
Thanks.
on
I still spent 6 months over here, which is a looooooong time in Afghanistan.
I think the heat shield will go back if I cut it. I want to see what other have done so I don't waste my time doing something that doesn't work.
on
The lower heat shield won't go back on with the ED downpipe. I am just seeing if any folks are having issues without the heat shield or if they found a way to get it back on.
Maybe this doesn't help too much, but I do know that someone did put theirs back on. Unfortunately I don't remember who. It was mentioned in one of the original ED Exhaust threads (I'm assuming the DP thread of course).
I didn't put mine back on and haven't noticed any damage. I have checked a few times since I've had it. Then again, I can't see everything down in there that well...
on
I am one guy that put my heat shield on after installing the ED dp. I posted pics in an earlier post. I did in fact cut in right down the middle in the vertical direction. There is about a 1/2" section exposed, but I also wrapped my pipe with heat tape so I think I am A-oK. Haven't had any problems yet and I check is every once in a while. Mini-maniac - shoot my a PM if you need any specific questions answered. I also have been waiting for you to get back to talk about your p2096 error code. I recently got that and am wondering if it has to do with the ED pipe and how you fixed it....Thanks for your service and safe travels back!!!!!
on
My wife said the CEL went off and hasn't returned. My DP is ceramic coated but I just worry about not having the heatshield. I will PM you when I get back and start to work on a solution.
EVMini
09-28-2015 10:20 AM
