I have narrowed it down to 3; DDMWorks, DOS and Forge. I haven't heard much about the Forge CAI and would like to hear of any feedback, so I can make my decision...thnx!
hahaha every intake comes with a free female to make car look good... none of them overdone model types tho... :P, keep it in ur engine bay stig hahahah
Will do Stig. I spoke to Clint via email...seems like a really nice guy. Oh, just noticed you said to order with the pre cut panel...can I just do the cut myself or is it that much more work?
Does anyone know the hole diameter that needs to be cut? I have a few hole cutter bits...just wondering if I have the right size.
I'll just emailed instructions to you. All will be revealed.
Also, you can borrow a hole saw from DoS for a $35 completely refundable security deposit. (Provided that it's returned to us 30 days after placing your order in good condition.) It's just not up on the website yet.
You need to hook Dunphyj and myself up with a discount on the baffle when you release it.
Stiggie
Noted. I'll see what I can do.
OK, 'Stiggie', so I have a question for you, JP, and Tim in SF.
Would you prefer a passive membrane baffle or butterfly (like a backdraft damper) that reduces cabin noise?
-OR-
A 'push-pull' cable actuated blast gate type baffle (like an old style choke cable) that you can work from the passenger compartment? A1) You can push the cable yoke in to close it it when your significant other is in the car, on long trips, & when you're not at events or tracking the car. Gains are slightly more than stock performance ~5hp more in the closed state and roughly stock sound. A2) When you're not in the car to talk about your feelings, you can pull the yoke to open-up the goodness.
Reason: Took out notes that might bias user opinions.
Finally got around to placing my order with dos...ordered the delte kit as well. I also came across a new quicksilver exhaust for $500 and jumped all over it.
