Drivetrain nm-eng what to expect?
What will i expect if I buy the Discharge pipe? Sound/smoother acceleration/ hp?
What about the new air charge pipe they just came out with. If i am correct does it take away the noise maker?
Im planning to buy both of them as my first mods and want to see if anyone knows if its worth it. I will eventually get an intake, exhaust, and so on....
But what would i expect from it? Any one know the difference between altas?
Thanks for the help =]
it's a sound thing... i have alta's... but they're cheaper and honestly they don't do much... it's eye candy for under the bonnet...
it's been said in many many threads, if you want power mods, go Intercooler, downpipe (or turboback) and tune... show is for BOVs, Boost tubes and Intakes... they all may make a small difference in the end, but as of right now the most you'll get is a little more turbo and boost noise... actual performance gains will be minimal at best for just boost tubes....
and yes, sig lists are like badges of honor almost... the more pieces the more fun (so most think... i disagree... i think it depends on what you want in the car...)
Sure there is some improvement. It probably won't change your 1/4 mile time by much though.
You'd be better off buying a sway bar for the same price or less $$. It'll help your straight line speed almost the same () , but it'll help your corner speed a lot.
If you want some gnarly noises without much hp gain (or maybe even a slight loss) get an open air intake.
x2 - fully agree although I'd save the downpipe for last since there will very possibly be CELs to go along with it.
09-25-2015 11:46 AM
09-25-2015 11:44 AM
09-22-2015 02:05 PM
