Drivetrain NO OIL!!!!!!
The car was running fine the whole time. No oil puddles no smoke nothing. I drive it hard but not that hard. I was pretty surprised. Thank God for synthetic oil. It has been 11k miles since the last service and it is due in 4k miles. I will be calling mini tomorrow and have them check it out.
oil is so easy to change that I think it's best to do it yourself (if you want it done right). I've had too many experiences w/ dealers and oil change places either not filling my engine w/ enough oil, over-filling, and stripping my drain plug that I stopped bringing my car in for routine maintance and just do it all myself.
How many miles were on the MINI since the service check and the pressure light going off? If you are getting the oil changed based on service intervals, you should be checking the oil on a regular basis. I've seen some nasty oil due to long interval periods.
4 quarts in 11K is high consumption. I think you need to check your oil more often (paging Capt. Obvious!).
As mentioned in the thread - don't trust anyone to service your car correctly other than yourself. There's a lot of hacks out there spinning wrenches for a living. Always check the oil level before you leave the servicing center. I'd bet they sent you away short on oil.
molala
10-02-2015 01:53 PM
09-04-2015 09:10 AM
09-03-2015 03:01 PM
09-02-2015 09:05 AM
