Drivetrain Adjusting Bypass Valve
I've been searching for a solution to my sluggish MCS and have come across bypass valve issues. I am wondering if there is a way to adjust the BPV without having to remove, perhaps a simple tightening of a screw somewhere? The idea of tearing apart my car is not one that exites me at the moment. Any help would be greatly appreiated.
If the bypass valve is having issues, that means the spring is probably in need of some stretching out. That does mean that the valve will have to come out, in order to get at the spring.
I've seen the work done before, and it's involved, but for a capable mechanic, it's fine. If you do decide to have the valve removed in order to check the spring, I'd suggest having the entire thing replaced with a Detroit Tuned Bypass valve.
That's just my opinion though. Hope it helps.
I think it's theoretically possible to adjust the valve on the car...
but you don't want to to it. You can't see the gaps around the butterly. If you do think it's the valve, you can just wiretie it shut. If you get your power back, then you know it's the issue. But there's a lot more that can go wrong with a by pass valve than just the stop. Spring issues, diaphram and shaft issues can all contribute to problems.
It's not that hard a job, just takes a bit of time to do.
Matt
Matt
MasterShaftner
09-04-2015 03:52 PM
09-02-2015 09:05 AM
