Drivetrain Alta's Turbo Inlet Hard Pipe Fitting issue
Old 01-28-2010 | 09:43 AM
ALTA_Jarid's Avatar
ALTA_Jarid
Quicker heat transfer? Don't forget that the inlet tube is pre intercooler and pre turbo. Drive an OEM car around for two hours and pop the hood open and grab the inlet tube. Is it warm? Yup... Now drive a car with a hardpipe..Yup the pipe is warm. I am sure the air inlet temps are close enough that after the air goes thru the turbo and thru the intercooler there will be virtually zero difference in air intake temps.
  #27
Old 02-04-2010 | 07:55 PM
Noegel's Avatar
Noegel
Pics of a customer-installed hardpipe? I'm looking to replace my ALTA tube with a hardpipe, and I'm willing to give ALTA a second chance if this tube is up to snuff!
  #28
Old 02-04-2010 | 10:16 PM
Rovy's Avatar
Rovy
I'll get some up tomorrow. Throw me a PM sometime tomorrow and I'll get to it.
  #29
Old 02-05-2010 | 09:21 AM
ALTA_Jarid's Avatar
ALTA_Jarid
If you decide to get one contact me directly!
  #30
Old 02-05-2010 | 07:46 PM
Noegel's Avatar
Noegel
Sure will... looking at your website, it looks like the clearance issue is solved... can't wait! Looks like a solid piece of machined metal!
  #31
Old 02-05-2010 | 08:50 PM
BamaCooperS's Avatar
BamaCooperS
I've had my Alta hard pipe on my '09 JCW since the first of January. It's an easy install and looks great. Based on my ScanGauge II, I haven't seen any relative increase in intake temperature. Of course the temp does vary from day to day, but it seems the typical delta between outside temp and intake temp is basically the same as it was with the stock plastic inlet pipe. Just as a note, I have the JCW kit filter cover with an Alta cold intake foam filter installed.
  #32
Old 02-06-2010 | 09:42 PM
09MellowJCW's Avatar
09MellowJCW
I just put one on a couple days ago. I did the inlet, the intake, and the BOV. All Alta. All went on without a hitch. I couldn't get everything perfectly straight though, as I'm sure you can see in the pictures. BUT... I was doing this in the drive, in 30 degree, windy, weather.
I'm going to my folks house in NH to visit this weekend though. While I'm there I'm going to be installing an M7 charge pipe, heat shield, and an Alta catch can. I'm going to utilize the space the CAI opened up and put the catch can on the firewall. Just need to get a couple of 3/4 to 3/8 adapters. I think I can even use the supplied L bracket to do it. I'll post some pics when it's all done if anyone's interested.
Anyway, I'll loosen the clamps up then, while I have a heated garage to use, and see if I can get it all a little straighter.
Hope this helps!
  #33
Old 02-07-2010 | 01:38 AM
david in germany's Avatar
david in germany
And what does the butt dyno say?
  #34
Old 02-07-2010 | 07:31 AM
09MellowJCW
I don't really trust the butt dyno. Seems to be a little biased...
I might Notice a little better throttle response though. The BOV feels like it makes some difference with higher rpm shifts as well. At least it sounds like it's doing something, and that's the real reason I put it on anyway.
But maybe the butt dyno is just trying help me verify my spending. I CAN tell you that my fiancé doesn't trust the butt dyno at ALL!
  #35
Old 02-07-2010 | 10:28 AM
pillar's Avatar
pillar
is there any sign of the tube slipping off the turbo?
  #36
Old 02-07-2010 | 10:34 AM
09MellowJCW
I don't think it could slip off unless the set screws loosen up for some reason. I keep checking it though. So far, so good.
  #37
Old 02-07-2010 | 10:08 PM
ALTA_Jarid's Avatar
ALTA_Jarid
Looks great! If it was me i might put a very small drip of blue locktite on those set screws...just in case. It is a very precise fit so I don't think you would have a problem coming loose as long as you torque the set screws correctly.
07-16-2020 12:54 PM
melscoop
03-30-2016 06:56 PM
AWOL
03-28-2016 10:51 AM
Da_jesus
08-25-2015 04:20 PM
ASRman
08-13-2015 09:33 AM
Quick Reply: Drivetrain Alta's Turbo Inlet Hard Pipe Fitting issue
