Drivetrain Milltek Exhaust
Milltek Exhaust
Had my exhaust installed yesterday - all except the front section. The shop i took it to wouldn't remove the front section of the stock exhaust with the secondary cat. Had a ***** of a time with the install things just didn't want to line up.
Now i need to find a shop or someone that can/will install the front section of the exhaust as well as the ED downpipe i have sitting in the garage.
I am sure i am not getting the full affect of the system. But it does sound nice - not overly load at all.
Anybody have recommendation for a shop in the chicago area that would be up for completing the install?
Going to install a new intercooler as well while i have the front end off he ground.
Hopefully everything will go smooth
Shop charged me $100 for the portion they installed. Going to attempt the rest of the exhaust install and downpipe install myself - had to go get a floor jack and some stands.
Milltek Exhaust on a 2011 MCS
Here is my experience with the Milltek CatBack exhaust as I tried to install it between the holidays.
Aligning all the pieces took some doing but I was successful from the Downpipe all the way aft of the crossbrace, but there is when it all went downhill (hell in a handbasket). The pipe coming out of the muffler(headed forward toward the Resonator) is angled to one side and not just angled down and forward. This throws off the muffler placement as well as the pipe between the Resonator and the muffler. My Distributor is "Looking into it". I strongly suspect a manufacturing error and when you see the photos you will probably agree.
http://www.mini4fun.info/2011_Millte...ek_Photos.html
S.
S.
my milltek has the odd angle as well.. but I was able to make it work,
but as the others said, it took some wrestling to make it all fit... and when cold I can feel a slight exhaust leak at some of the seams..
my exhaust tips are not straight/symetrical.. almost like the jig they used to put it together was off...
it's not that noticable on the car unless you look closely..
Did you have to bend the factory hangers away from the stock positions to make it work? Was the V-Band connection a sharp shoulder?
I added comment and more photos to my web site to show how Milltek makes a V-Band surface.
I also updated how Way Motor Works and Stratmosphere treated this issue.
Stephen
Stephen
Nothing "Posted Below"
You mentioned "Exhaust leaks when cold". Does anyone else experience this with Milltek? Does you smell gas leaks or smell burning plastic from the Tips hitting?
S.
Same problems, even with an older car.
That was a nice write up with photos, thanks! What year is your Mini?
S.
patsum
26
05-29-2021 06:29 PM
embiggenedmini
10-15-2015 12:36 PM
