Drivetrain Seafoam and PCV issue
OK so I have decided to swallow my pride and ask for some help. I tried doing the Seafoam treatment but have no idea how to get the PCV tube off. I squeezed and twisted and pulled every which way and still couldn't get it off. Is there some trick i'm not doing right? Any suggestions would be greately appreciated.
I had no problem on my Cooper s removing it by pressing on both sides and pulling straight. You should hear both sides click when pressed. My Cooper was another story as I was only able to press on one side with my fingers so only one side clicked. The valve cover was is the way. I used a small screw drive and carefully applied pressure to the clip.
i did not know this until my teacher told me. basically the carbon/whatever's built up in the engine is being broken down and passing through the engine itself then out the exhaust. all the junk passes through the spark plugs and then the plugs become fouled (sorry i dont remember exactly how my teacher explaing to me)
i'm guessing that if your AFR is good, then the plugs should clean themselves off after a certain amount of cycles. the only way to be sure is to pull the plug when the engine has cooled after you've seafoamed. then pull it again after X amount of miles, let's say 50 miles or something like that to compare.
Funny, I just did it to my car this weekend too. It definitely helps out. I didn't change the spark plugs though.
I had a little difficulty taking the PCV tube off. But you pinch the ends of the PCV tube and pull towards the rear (the firewall). You might have to wiggle a little as well. It was easy one time, and the second time I struggled a little.
Also, how much seafoam are you supposed to use? I used half the container.
Based on recommendations elsewhere in this forum, I did my first SeaFoam treatment 3 times at 23K before an oil change. The key seams to be adding each 5oz treatment as slowly as possible, at least 5min. This allows for even distribution over all cylinders. Also, let it stand and soak at least 1hr before start up. Used an 8oz plastic baby bottle with the one hole nipple to apply and squeezing hard it took ~8min to empty. Result? Glass smooth idle, quick start up and no stumble on launch. Just got the RMW tune and the ~4000rpm hesitation that others have reported seems to be gone as well. Plan to SeaFoam before every 6K oil change from now on unless the rough idle/launch stumble indicates otherwise. Doubt the stuff would have been around for 68yrs if it didn't work.
PS: If you think getting the PCV tube off on an OEM airbox is fun, you oughta try it with an m7 super AGS!
In the UK I have often used a product called 10K Boost and this used to be sprayed into the throttle body on my old Petrol Injection car.
It needs to be sprayed into the air inlet so is this PCV the same place for me to use?
Thanks to anyone who may be able to help. My 2006 R56 MCS has 25k on the clock and I am firm believer of maintenance like this and additives in the petrol to clean out the fuel system.
