Drivetrain Boost Gauge rattle?
on
Boost Gauge rattle?
Yesterday I installed an STRI X-Line boost gauge. I finally used my BSH dual boost tap for more than a PCV block off.
Anyway, the new gauge works just fine. The problem is that it rattles. The noise corresponds with the needles movement. I took the gauge back out of the holder and I can feel the vibration that is causing the rattling noise. It seems to make noise at lower speeds, during vacuum.
Anyone else run into this? Do you think I got a defective gauge, or did I just not spend enough?
I was thinking that the boost source might have something to do with it, so I took the plug out of the boost port. It did the same thing with it open.
on
Hey Tim, I think I forgot to mention that the prosport gauges have the same problems with rattling noise. I was going to tell you but I got carried away with our conversions. Here is the thread of how to fix it
https://www.northamericanmotoring.co...ost-gauge.html
and here is the Defi gauges I was talking about :
http://www.jscspeed.com/catalog/Univ...surements.html
I bet these won't rattle. I plan on getting this boost gauge:
http://www.veisystems.com/bom-m.html
and this combo oil pressure/oil temp gauge. http://www.veisystems.com/d1-opmotf-m.html
I will use my Scangauge for water temp.
I had some major rattling in my coolant temp gage, same one as my boost gage; come to find out it was the button for checking highest readings and setting it and what not. I went to the hardware store and bought a couple supper small o-rings and put them around the button. The button is harder to push down, but no more rattle!
A'PEXi gauges
I have fitted Apexi boost gauge and Exhaust gas temp gauge with the electronic control unit with peak/hold-warnings and real time replay.
They both work excellent. Bare in mind though that these are electronic gauges and cost far more than a simple mechanical gauge. But they proved to be very accurate and super responsive.
Recommended.
Recommended.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 06:27 AM
molala
10-02-2015 01:53 PM
