Drivetrain ECU Mod, Aftermarket Parts, and Warranty
#26
They won't on stuff like that. However, pop your engine and take it in with the engine mods and see how accommodating they will be. Even a dealer that says they are mod friendly will try to bow out of a 5K + repair if there is any possibility that a mod may have been at fault.
#27
There is information stored along with the fault, but I have never seen boost pressure recorded with engine DTCs. You are correct that it would be an obvious telltale. There is also a tamper code which does not illuminate the check engine light. If the tuning software doesn't recognize and erase it, it would be captured by a factory scan for trouble codes. I think most flash-to-eprom softwares clear this code. From what I've seen piggybacks don't.
I have a print out of my DME fault from the tech who worked on my car...and boost pressure is clearly on there. Maybe not every fault displays it, since mine was directly related to high boost pressure.
I can scan a picture of it...it has the boost pressure that the car saw, and has the boost pressure set-point at which a fault will be triggered. Both measured in mbar.
#28
there is a good amount of oil around my 3rd and 4th spark plug coils. its actually the second time im going back for it. i wonder if the dealer just cleaned it off the first time and called it a day
07-16-2020 12:54 PM
12-23-2015 10:36 AM
