Drivetrain help with cell???
Generally speaking, I think it supposed to light up when the engine takes too long to warm up to operating temps....so it would be coolant/thermostat related, you would be correct black r56s.
Could be the absense of the cat creates a initial heat reduction triggering the code. But that is a guess.
no.
Its not becuase of the coolant or because the engine takes to long to heat up... its becuase you changed the cat. The engine it the mcs is monitonerd more acute then most. getting a cat that will run effiecently enough is no easy task. thats why downpipes arent 300 dollars from the factoy....
