Drivetrain The Official ALTA AccessPORT Thread
#2851
#2853
That's one of the joys of having a Mac...not everything is designed around Mac OS. Run Windows through Bootcamp for situations like this.
FWIW, when I had my AP it worked fine on my Mac.
#2854
#2856
What version of OSX are you running?
#2859
#2861
#2862
This is what I'm thinking as well. Alot of folks who are more familiar with Windows do this but with OSX you need to do things a bit differently.
Look in your downloads and you should see 'APmanager.DMG. open it. when you do this window should pop up on your desktop
Take the file on the left and drag and drop it into the application folder right next to it. That should be all you have to do. Once thats donw do like NY_R56 said and then go find it in your application folder and open it from there.
OSX 10.6.8 is snow leopard. I can't recall if that's what I had when I got my AP. If not then it was Lion. I've since upgraded to Mountain Lion and the AP manager has worked fine on all.
#2864
#2865
Sorry I'm not much help so far. I'm running version 2.0.2.3 of the AP manager. Hit up Alta chris and see if he can send you the latest version. I'm guessing the version on the alta site is the original since I think you said it downloaded as version 1. If he can't get it to you I can try this evening when I get home.
#2866
well if you could help me that would be greatly apperciated.
#2867
#2868
Hi guys, I recommend for both of you to contact COBB directly. They are the ones that make the software, and you can talk to the guys that actually make it by giving them a call: 866.922.3059
#2869
Well I called them and they said they do not have an update for windows 8 yet and no timetable and no advice on a work around. They said to keep monitoring their web site for an update as it should be announced there when available. So none of that is a real good answer. Fortunately I have another computer with Win 7 I can use.
#2870
Does anyone here know if the ECU's MINI uses are JCW and MCS specific units or do both models use the same ECU? I have an issue where I think I received the wrong map for my car and it made me wonder how the ECU type (ie. H901B for instance) figures in these cars.
#2871
Experts wanted... anybody wanted to chime in on this discussion ?
https://www.northamericanmotoring.co...e-is-this.html
#2872
Guys I have a problem not sure if it's the Alta Accesport.
I installed on monday in my JCW 11 the Alta CAI, Alta exhaust, Alta FMIC, Alta spring upgrade and everything was fine. Yesterday installed the Accesport in stage 1 FMIC and did one hour driving, normal driving in the city, probably 30-40km/h and just two hard acelerations to feel the accesport. When I was near my home the temperature light came up, when I was parking the car in my house it turned red, well shut down the car and the fan came up at very high speed. Look's like the termostat is not working, because the reservoir was cold. Do you guys think it could be a bad flash? O just bad luck and need to remplace the termostat?
I'll unistall the accesport and drive some miles to check if it's working again.
#2874
