Drivetrain The Official ALTA AccessPORT Thread
#3526
I wanted to ask you questions as they will sound stupid here...lol
I just want to know what I will and should expect from the normal stage 1 and then add the 10 WHP of the stage 1 FMIC once I upgrade the other mods
#3532
Just had to ask....Im new to mini and not sure if the JCW stage 1 will interfere with the AP tunes
Im looking for enhancement
Im also looking to do the hot side silcone tube and upgrade the FMIC
Just looking to get this puppy move a tad quicker
So all in all....I should be good to go for now with the stock pre loaded tunes and the JCW stage 1 tune I have already in the vehicle?
Thanks in advance
#3533
i have access port with JCW stage one for a month of so. There is one map stage 1 tps 91 octane. The stage 1 have many variance as to the octane you use. I think i saw 92 octane as well. Now i had completely stock with just alta air filter. It was a nice little boost.
Just today, i changed it to stage 1, 91 octane, tps, fmic. Also had the aem intake install.
So yeah..if you have bone stock JCW and access port, you can go ahead set to stage 1...disclaimer, i am not responsible for your engine blow up etc...hehehe
Thanks Mike!
Thanks in advance
Thanks in advance
#3534
I would make sure that your intake ports don't have severe carbon buildup before getting too aggressive with the tune. You can search threads on this forum on how to check it.
Severe buildup restricts the airflow, and since this is a 'canned' tune, made for a generic vehicle, it cannot compensate for your specific vehicle.
Just run the stage 1 tune, for whatever gas that you have available in your area.
Have fun,
Mike
Have fun,
Mike
#3535
How you liking the AEM intake? Thinking about switching my JCW intake for it.
Seems to be more functional
Have fun,
Mike
Have fun,
Mike
#3536
I recently (2 weeks ago) picked up a 2010 Mini Clubman S with stage 1 JCW tune
I just got my Alta AccessPort late last week and I'm having issues with the AP connecting to my mini.
I can get to the part selecting the tunes half the time and the other half it won't even get to that point.
This is the error I get, how do I over come this?
Once I'm able to, which tune do I select?
I know Stage 1
But I have a manual transmission and the JCW tune if that makes a difference and sort of falls into stage 2?
Thanks guys
I know Stage 1
Thanks guys
#3537
You should not run Stage 2 unless you have a 3" turbo back exhaust. I have a 2007S JCW Manual, ECU H910B and only run Stage 1 FMIC 91oct at best because I have an aftermarket larger FMIC. I would certainly not run Stage 2 unless I wanted to blow up something.
As for the error, better check the connections as it says. Never seen that before except when mine was still married to another car. I think that's a different error though. Good luck.
#3538
Thanks guys
Thanks guys
Hello, usually you will get that error if the AP needs to be updated, or something isn't plugged in all the way. If it does work sometimes, make sure that you're hitting the start button twice to make the car go into the ON position. If it isn't in the ON position, the AP won't be able to talk to your ECU.
If your car is basically stock with the JCW tune, then you will want to run a stage 1 map.
#3539
Ill update below this
It worked shortly after and I did load Stage 1
As Carey, I have everything he has
'JCW Manual, ECU H910B' except being a 2010 clubman S
Either way its loaded and I took my clubby for a rip and
WHOA!!!!!!!!
This mini is AWAKE!
I was having fun within the tune and now I was literally grinning ear to ear and I only had time for one trip around the block
Now, I want to get the larger intercooler and then to stage 2.
Difference between stage 1 FMIC and Stage 2 91 is the 3" Turbo Back?
Any recommendation guys on what to go with?
Im wanting more power now....or within a month as this will suffice till then
#3541
#3542
Good afternoon NAM,
I was hoping you might be able to answer a question for me regarding the AP for my Mini Cooper. I know that the support for the Mini AP is no longer there but I really do not have anywhere else to turn.
I have enjoyed my AP on my 2008 R56S for over a year now. But within the last couple months I have experienced a bit of smoke from the exhaust when I apply the gas petal and engage the clutch when leaving a stop. This happens a couple times a day, random.
It doesn't do it any other time but when leaving a complete stand still. I give the car about 1000-1200 RPM's and engage the clutch and a decent puff of smoke is witnessed. Pretty embarrassing. It wont do this between gears when accelerating or during heavy acceleration.
Any thoughts?
Any thoughts?
#3543
Good afternoon NAM,
Any thoughts?
Any thoughts?
A quick check on your turbo air inlet should let you know if you have excess crankcase pressure. Lots of controversy about this, but it's easy enough to check and eliminate as a problem.
#3544
Guys need help I just bought AP from another member here and I'm having trouble with not recognizing my car. It's asking to contact AP for update. How do I go about doing that?? I took a pic below of the issue. Please help thanks
Attachment 81836
Attachment 81836
#3546
Did you download the ap manager on your computer and hook the ap to it for any updates before putting it in your car? What year is your car? Model? Sent from my iPhone using NAMotoring
Unknown ROM usually means your ECU isn't known to the AP if I remember right.
#3547
#3548
Sorry for delay response guys and thanks for your tips/help. I had to download the Ap manger and update the firmware on the unit itself for it to recognize my car, once I did that it worked w/o any issue.
I have 2009 MCS with Invidia catback, and AEM intake, I chose 92 oct stage 1 option.
