Drivetrain The Official ALTA AccessPORT Thread
#452
If you are talking about the 23 PSI it doesn't get that high often and when it does it doesn't stay there very long. My RMW tune did the same thing. If you have a stage 3 MINI both tunes are set for 20 PSI and in an over-boost situation both will top out just under 23 PSI.
Alta is not pushing the turbo to failure by running too much boost anymore than Jan is.
The Alta tune does do a better job of holding the boost pressure right around 20 PSI though compared to my RMW tune.
#453
We are working on the 0-60 and quarter mile features on the AccessPORT and need some testers! If anyone is interested, send me an email at tech@altaperformance.com or a PM, thanks!
#454
I'm still on the stock tune so being in overboost is the only way i get up to 12psi on my '09. It sucks so bad. I bet my car sounds kind of weird when I'm constantly doing a double pedal mash to get into overboost. I cannot wait to get a tune to get some butt-tingling torque.
Double mash? i thought it was WOT under 4k rpms?
#455
#457
#458
The auto AP is still in testing, but if you have a code reader, we can sell you an AccessPORT right away.
We have recently found from an auto tester that starting and stopping the car 4 times also clears the codes. Keep in mind that the CELs related to the AccessPORT are only temporary, soon we will have a fix. It should be ready in the next few weeks.
We are looking for auto tester in Austin TX area, to help us develop the auto maps quicker. If you are interested, give us a call and ask for me!
#459
#460
I went out to my MCSa and tested this. I reflashed my current map which caused the CELs to appear. On the fourth restart the CEL was still present. On the fifth restart, viola, the CEL was gone.
#463
when i go wot fast it over boosts. Unless I'm at anything above 4k, then when i get to the next gear and go wot equally as fast it overboosts.
i will see this double mash technique on my way home from work
#464
Something i'd like to see is the AccessPORT be able to tell if you're Emissions ready or not, and if not tell you what parameters haven't been met yet... i know some 100 buck code readers do that like the one i use. just a simple red yellow and green light for emissions readiness and little codes flash up to to say which ones aren't met yet... like O2 sensors... fun little gadget to have. Also tells you what the codes mean when any of them come up.
how's that Dyno function coming by the way? Any testers for the 0-60 estimate and 1/4 Mile reader?
#466
Would love to hear an official "yes", "no", or "it's on our to-do list". … well, ok, I would not love to hear "no"
#467
#469
#471
I've had a couple versions of it, originally it was turned down a bit but Jeff turned it up for me several map files ago. He said if he makes mine any louder it might start interfering with my cruise control.
I love the way it makes my TBE sound though, it's awesome.
#472
We are working on the burble and pop, I'm not sure at this point when it will be ready, but it will be soon!
#473
