Drivetrain The Official ALTA AccessPORT Thread
#676
UPDATE (AGAIN ):
After some personal reflection on the 91 Octane Clients I have changed my mind.
$795 on the ALTA AccessPORT
When you want to order just go to our website CLICK HERE or call us to order! Happy to help! PLEASE note if ordered online it will ring up at $895 and then a $100 credit will come back to you after the sale is completed. Ordering via phone, will only be charged $795
OFFER LASTS THROUGH 10/15/2010 and is a NAM only deal!
Order quick to take advantage!!!!!
Adam @ ALTA Performance
#677
Is it reasonable to expect to get near 40mpg with the "eco friendly" map on a stock MCSa? I ask b/c the gas savings could be a talking point as I try to convince the wife the AP is a worthy investment ....
#678
Hope that helps!
#679
not necessary but bigger injectors and correct ECU are needed. I'm not running E85 now because I'm impatiently waiting for alta to have E85 mapping.
#680
/sarcasm
I'd say e85 would be a very bad idea in your MINI.
#683
yes it'll be very bad because you will be addicted to it and hope you can have more E85 pump around you.
#685
#686
Thanks for asking! In the meantime if you want a Staged Kit, PM me and I'll build ya one!
Have a GREAT weekend folks!
BTW: 91 octane and Auto Guys have until next Friday to take advantage of the $100 discount on the ALTA AccessPORT!!!!!!
#688
I run E85 here in the UK, and have had no trouble with the engine or cat, in fact the engine loves the stuff, my only bind is that the nearest fuel station supplying E85 is 44 miles away from my home, so I have to think before I drive any distance away from areas supplying E85, have I enough to the next available supplying station!
#689
Hey guys. So Ive had the AP stage 2 installed in my 09 jcw for a few weeks now. Whenever I push my car, I always have traction completely off. However, the other day, I had DTC on and punched it in 4th gear around 3k rpm. My car began accerating as the rpm needle went up and at about 4-5k the rpm needle shoots up faster than i am actuall accelerating.
I started to think my clutch was slipping for whatever reason but did not detect any burnt smell of the clutch. I tried it again with traction fully on and same thing happens. It doesn't happen everytime, only sometimes.
Is anybody else experiencing this? I would think especially because I have a jcw my clutch would be able to handle this. Any thoughts on what this could possibly be or what's causing this? Thanks!
#690
I'm intending on just using a stand-alone progressive injection setup with a high boost map. Would be gr8 if there was some way of integrating a w/m injection system with the access port mapping to get the most out of it.
#692
ok… I'm staying away from the site for a bit.
is anyone else seeing this?
https://i.imgur.com/o70AA.png
https://i.imgur.com/JW3PW.png
I sent a message to the site operators, and I'm hoping to hear from them soon saying it's all been straightened out.
#693
Seeing that you're probably smart enough to know whether your tires were slipping or not, i'd probably say they werent.
it sounds like its your clutch- you don't have to necessarily smell the clutch when its slipping, especially ~4krpm in 4th gear, means you're prob going about 70-80, so you may not necessarily smell it at those speeds either.
My brother's modded audi had a slipping clutch, and it'd be the same situation u describe. accelerating in 3rd gear at 3k rpm under boost, it'd start "revving" without the matched acceleration.
Depending on how you drive normally, (some people wear down the clutch quicker than others, with 1st gear engagement release, downshift, rev match, etc etc), the clutch may have been worn down before the extra power-- and now with the extra power its having a hard time gripping.
I would suggest flashing your tune back to stock and seeing if you have any slipping characteristics in any gear at WOT. If you do, its def not the tune and prob the clutch. However you may not experience it since theres less power, so not sure what to tell you
#694
Yea before the tune I definitely did not have this power because there wasn't enough power. It may be the clutch slipping, but I was wondering if anybody else was experiencing this problem. Maybe it is my clutch slipping and may have to look for an upgraded clutch
Edit: I should also mention that this problem does not happen when my traction control is completely off, so I also don't want to say it's the clutch slipping because it would slip regardless of traction on or off I believe
#695
#696
I was going to help be a tester for the A.P. and the Alta water/Meth system (I love it by the way) and I still will, but I sprained my ankle and knee doing sports, and I cant even press my clutch in. I will need to heel before I can drive, and help.
hey no pain no gain
Thank god I have friends to drive me to work, or I would be in real trouble...
hey no pain no gain
#697
hey no pain no gain
hey no pain no gain
Get over it.
Mark
#698
