Drivetrain The Official ALTA AccessPORT Thread
#2151
So got my AP second hand today. Loaded up stage 3 and................ Only hitting 15.9 PSI of boost and fells like its hitting a wall when it shifts. Its weird. It cuts boost drops the RPM's to 5k then Shifts then revs back to about 5.5K and then kicks the boost in. And it shifts HARD!!!! tried updating the AP and AP manager still a no go. anyone have any ideas?
2010 MCCSa Alta intake and hot side boost tube, SAMCO turbo inlet hose, Forge FMIC, ALTA DP to 3" straight pipe to 2.5" Magnaflows, Forge Diverter valve. I think thats it as far as engine mods.
#2152
A recap and question
I read the entire post, and understand the product pretty well. I have an 08 MCS auto, stock driveline (except for an oil catch can). This is what I know:
1. Maps are available for my car, I am totally in stage 1 territory.
2. Fuel economy tends to increase 1-2 mpg, once we 'learn' to keep our foot out of it. Special 'economy maps' are not available.
3. Alta continues to give good customer support.
4. Alternate TPS mapping is limited to the manual shift cars, auto cars use the regular mapping.
I have one question (I don't remember defininitive answers):
Does the AP reduce the throttle 'delay' that exists on this car? Some guys had coined the 'lag and lurch' phrase. Sometimes the car is difficult to drive smoothly when trying to drive efficiently.
Any comments would be appreciated.
Thanks,
Mike
Thanks,
Mike
#2153
I had a few guys with autos revert back to stock for visits to the dealer and the loss of throttle response was there biggest complaint.
#2154
I have a strange message popping up from the AccessPort manager. I just upgraded to 2.0.1.6 and it tells me now that "Your AccessPort no longer contains the ECU data backup from your vehicle. If not restored, the AccessPort will restore a "stock" ROM when/if you uninstall it from your current vehicle. Restore ECU Data backup to AccessPort?"
First - what does this mean? I have never deleted anything from the AP, so where did my backup go?
Second - I think I have the .ROM file stored somewhere on my PC. Is that the backup?
Third - after I click "Yes", it says "Stock ECU data backup from your vehicle already exists on the AccessPort. Do you want to replace it?" --> if I view "All Files" on the AP, I do not see that file. If I go to C:\Users\<username>\AppData\Local\APManager\backup \, I _do_ have my Mini backup in there.
All of the above scares the bejesus out of me, so I'd appreciate some answers. 2.0.1.5 never asked me anything about any data backups, so is this a 2.0.1.6 bug?
[edit] the .ROM file *no longer* shows up on my AccessPort as of half an hour ago (although it used to, until I upgraded to 2.0.1.6 the same half an hour ago).
#2156
#2157
It sounds to me that it would install "stage 0" onto your car if you were to uninstall it for sale or some other reason. It doesn't remember exact ECU data and stage 0 is very similar. I would vote for backing it up and replacing the file if you haven't done so already but maybe Mike can chime in as well.
#2158
jbourne, Are you doing a beta update? If so, we made a change to how the ECU is flashed, and the AP Manager may recognize your saved ECU data as being different. It's not a problem, you'll just need to reinstall the AccessPORT on your car and it'll fix it.
#2159
#2160
What should I do, exactly? Should I answer "Yes" to replace the backup? Should I uninstall the AP on the car? Please give details
#2161
#2162
Answer yes to replace it. If you updated the AP with beta, there's something that we are working on that flashes the ECU differently, and it doesn't recognize the backup, but it will be fine. If it's installed on the car, just uninstall it, then reinstall the appropriate map.
#2164
Standard mapping options and updates to those maps will come from Alta. Any maps that are released from the Cobb retail facilities are considered "custom maps" are are not part of the normal AP update.
With that said we could taylor the maps any way a customer wants essentially, with in reason of course.
#2165
#2166
#2167
On the AP, what you want to look at it is just "Boost" it will give you the reading in psi that you are looking for
#2169
I'm sorry, the AccessPORT is not compatible with the R60.
#2173
Your best and safest route right now would be to swap maps to match the fuel octane your using.
