Drivetrain WMW Performance Blow off Valve -- opinions?
Old 05-11-2011, 09:59 PM
barnoun's Avatar
barnoun
barnoun is offline
Originally Posted by Alexander!
quite possibly the most annoying thing i've done on a car so far. first of all whoever put in those bolts torqued the crap out of them. when i took them out there were metal shavings all over the place. getting them back in straight was a pain and i lost one somewhere in the engine bay. luckily the home depot sells the same bolt in black oxide finish.
-Alex
The bolts have threadlocker on them, what you saw might have been threadlocker residue. When I reinstalled mine I think I stripped one of them, everything's been working fine though so I'm in no rush to find out if it did get stripped.
  #202
Old 05-12-2011, 04:41 PM
Alexander!'s Avatar
Alexander!
Alexander! is offline
it was not locktite but definitely metal shavings. plus, the threads looked real crappy.
there is definitely a noticeable difference in the car but i'm not sure it was worth the hassle.
  #203
Old 05-12-2011, 04:52 PM
n1tr0's Avatar
n1tr0
n1tr0 is offline
Sounds like someone was in there before and cross-threaded the bolts
That's definitely not the usual experience.
  #204
Old 05-12-2011, 05:10 PM
Dwight Walhood's Avatar
Dwight Walhood
Dwight Walhood is offline
No pain, no gain! LOL
  #205
Old 05-12-2011, 05:14 PM
gregsmini's Avatar
gregsmini
gregsmini is offline
I put the WMW Blow off valve in about two weeks ago. I didn't think it was that bad to install. I removed the cold air intake hose and moved the coolant tank and took my time. Not really a problem.
I replaced my spark plugs at the same time, so I'm not sure I can make a fair before and after comparison. But..it sure runs much better. The low end is much smoother and the engine feels stronger.
I have only gone through one tank of gas and the mileage didn't change. I'm going to be watching it long-term but so far very pleased.
  #206
Old 05-13-2011, 03:26 PM
dboard7's Avatar
dboard7
dboard7 is offline
Just got mine on it wasn’t the easiest thing to do, but i did the hot side pipe at the same time and that sucked! i couldn’t get the muffler off it took a bit of work lol but there in now, time for the intercooler! if I can decide what one to go with
  #207
Old 05-13-2011, 03:55 PM
Dwight Walhood
The Helix stepped core FMIC! Had mine since last year and it works great. Intake temps are either at or within 2-3deg of ambient even on blazing hot days. BTW, I had mine coated with thermal dispersant before install.
  #208
Old 07-06-2011, 04:56 AM
jbourne's Avatar
jbourne
jbourne is offline
The install is really not THAT bad. I looked at it long and hard before I took anything off, then I took off the CAI pipe, and AS LONG AS you have a proper angled Torx T30, you should be able to do remove it without removing the coolant reservoir. Mine was just right, so I was able to complete the entire job with only removing the CAI hose, and nothing else.
The bolts were torqued but nothing excessive. Difference is quite noticeable, even though I tried it for all of 100m so far - we'll see when I go for a drive later. Seems to be quite worth the 60-some bucks!
  #209
Old 07-07-2011, 08:05 AM
Speedin Bob's Avatar
Speedin Bob
Speedin Bob is offline
Been about six months since I installed my WMW BOV. Still very happy.
  #210
Old 01-25-2012, 07:47 AM
axleR56's Avatar
axleR56
axleR56 is offline
I installed the valve a few days ago, the whole process took me about 40 minutes, (10 of which were running to the store to get another t30 bit) LOL
My initial impressions are very similar to what others are experiencing. Low down power delivery feels buttery smooth now, and there is no more hesitation/jumping during accel/deccel. This feels like how the car should have came from the factory.
Having the Scangauge installed too helped me to notice that I now build boost faster and hold it better during shifting. This is no placebo, the proof is in the pudding. Anybody with a boost gauge or a scangauge will be able to notice this on something other than the butt-dyno.
  #211
Old 01-27-2012, 07:55 AM
Spridget's Avatar
Spridget
Spridget is offline
Interesting stuff... so can you notice a difference in Sport Mode?
Spridget
  #212
Old 01-27-2012, 08:17 AM
axleR56's Avatar
axleR56
axleR56 is offline
Spridget
I notice a difference in both Sport and normal. However, I still find it annyoing to drive in normal mode. There shouldnt even be a button imo, should be Sport all the time.
  #213
Old 01-29-2012, 09:28 PM
mini chili's Avatar
mini chili
mini chili is offline
Can I put a bov in a 2011 Cooper S? If I can, what BOV would i use!!!
  #214
Old 01-29-2012, 09:31 PM
Step's Avatar
Step
Step is offline
has anyone noticed the part number is shaved off....
I opened mine....
the spring was the same,
the diaphram was the same
the housing was the same
....... Am I missing something?
  #215
Old 01-29-2012, 10:43 PM
inh's Avatar
inh
inh is offline
Step I think 11+ minis come with the updated valve already
  #216
Old 01-29-2012, 11:58 PM
mini4tide's Avatar
mini4tide
mini4tide is offline
Well, if anyone on here is skeptical about installing this, don't be. It was a VERY simple job. Just be mindful when you're close to backing out the screw, grab it with your fingers as you slide it out, and install it the same way. 15 minute job once you remove the intake pipe. Did it make a difference? Meh, not really on first impression. I'll give it a hard run tomorrow and see for sure.
  #217
Old 01-30-2012, 05:55 AM
axleR56's Avatar
axleR56
axleR56 is offline
I opened mine....
On mine, the difference was noticeable. Like the pictures posted in this thread earlier, the WMW valve extended further out than the stock one. My stock spring also felt marginally weaker. The overall design on mine was slightly tweaked as well (the holes at the top of the valve were shaped differently).
  #218
Old 01-31-2012, 12:56 AM
mini4tide's Avatar
mini4tide
Ok. I digress. With a hard run, I noticed a huge difference. Much smoother gear change in my auto. And just as everyone else has said, the power is useable sooner. Great mod. I'm sold!
  #219
Old 03-05-2012, 07:27 AM
ORazor's Avatar
ORazor
ORazor is offline
I've seen different accounts of whether there is a noticeable noise with the new BOV(or DV, whatever your mood is). For me, there is a noticeable whirl (a glorified whine) and whoosh while I accelerate. Can anyone else comment? I feel that the sound is the most noticeable difference - more so than any performance gain.
  #220
Old 03-05-2012, 08:03 AM
tvanhouten's Avatar
tvanhouten
tvanhouten is offline
Although all of the parts look the same, I thought I read the spring is stiffer than the OEM one. Also there was speculation that this BOV is actually the one for a JCW and that is why the serial number is shaved off (maybe to keep that a secret?).
I opened mine....
  #221
Old 04-01-2012, 02:55 PM
fullymooned's Avatar
fullymooned
fullymooned is offline
I am having a real hard time trying to put this BOV in. One of the bolts is rusted so TBIT30 is not working. Is there a way to remove this bolt? Also how can I put this in without removing the coolant?
  #222
Old 04-01-2012, 03:38 PM
axleR56's Avatar
axleR56
axleR56 is offline
Taking the coolant res out will take you 5 minutes and save you about 30min of trying to get a hand in there...install is much faster with it gone.
  #223
Old 04-01-2012, 03:50 PM
fullymooned
Do you completely take the coolant reservoir out and keep it aside (out of the car) or do you mean just remove the one bolt thats on it.
Just removing one bolt doesnt give enough space to work around there. Completely removing coolant reservoir means coolant leakage and putting hose clamps back. I think there are 2 hoses to the reservoir(right?)
My bigger problem is that one but is rusted.
  #224
Old 04-03-2012, 12:14 PM
fullymooned
I have lost some of the bolts in the engine bay. Where can I get them from and what are the dimensions. Thank you.
  #225
Old 04-03-2012, 03:41 PM
rum4's Avatar
rum4
rum4 is offline
You would have to use this one http://www.waymotorworks.com/forge-blow-off-valve.html
Quick Reply: Drivetrain WMW Performance Blow off Valve -- opinions?
