Drivetrain Gauge mounting options
Old 12-29-2003 | 08:15 PM
KSMini's Avatar
KSMini
I saw a piture either on this forum or on Mini2 that showed gauges mounted on either side of the tach. Basic bracket with the buckets attched. Does anyone remember seeing it? Been looking but not having any luck. Am I imagining things? Thinking about a boost gauge on one side and oil pressure on the other.
Any help greatly appreciated.
Old 12-29-2003 | 09:26 PM
hondacivic's Avatar
hondacivic
I do know what your talking about. its a gauge pod! search the form for "gauge pods" you'll find lots of them
sorry i cant pont you to a web site with them right now,...
Old 12-29-2003 | 09:43 PM
TonyB's Avatar
TonyB
KSMini, I think you are referring to the PROMINI set-up. I just installed it last month, and made some comments about to it over on MINI2. I think this is what you are talking about:
http://www.promini.com/products/gauges.shtml
I had been wanting it for a while, but when they made the boost gauge go up to 30, I wasted little time in getting it...
Old 12-30-2003 | 01:22 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Try outmotoring.com and see the alta gauge pod for about $165.
Also Piloracing is thinking of carrying something similar for less.
https://www.northamericanmotoring.co...ic=20975&8
Old 12-30-2003 | 05:29 AM
KSMini's Avatar
KSMini
Thanks to you all. Exactely what I was looking for.
Old 12-30-2003 | 05:37 AM
nparker's Avatar
nparker
You can make a low cost mount similar to the ProMINI and Alta for about $40. I am in the process of finishing mine this week and will hopefully post pictures later. VDO gauge cups can be purchased at Summit racing for $15 each. A piece of aluminum stock 1" x 8.5" can be used for the mount to the back of the tach, approx $5. Assorted standoffs and screws, another $5. Aluminium, screws and standoffs can be found at Lowes or Home Depot. For those of you with Nav, take the width of the gauges and add 1" on either side. Summit has the matching gauges for about $55 for electric oil pressure and $45 for the mechanical boost. An electrical boost will run about $190+. That is where the cost comes into on the ProMINI setup. I'll have about $150 total wrapped up in mine and it will look great!
Old 12-30-2003 | 05:42 AM
vdubdoug's Avatar
vdubdoug
I have a Guage mountiing bracket that works for Nav and Non nav cars. I am trying to see if the man who created it will make more. It does the same thing as all the other guage kits but costs allot less.
The main cost of all these guage kits is the guages themselves. an Autometer boost Guage (electrical in 2 1/16 size Part # 4377 runs around 180.00 dollars)
Old 12-30-2003 | 02:50 PM
TomM's Avatar
TomM
I saw some website offering the Promini set-up but with the mechanical gauge. If I can't find it, take a look at some primarily BMW sellers, and they have a section for the MINI stuff. I'll reply again if I find the site.
Here - http://www.hmsmotorsport.com/store.p...1c49b36f6#1249
_________________
2003 Cooper S
Madness Intake - Mini Mania Pulley - Black BBS RZ - Yokohama Parada Spec2 - Eibach Springs - Borla Race
Old 12-30-2003 | 05:03 PM
speltzer's Avatar
speltzer
Make sure you attach some photos. I am curious how it looks
Old 12-31-2003 | 06:02 AM
ColoradoMark's Avatar
ColoradoMark
nparker,
are you teeing into the oil pressure switch mount for the pressure gauge?
Old 12-31-2003 | 06:13 AM
SumWon's Avatar
SumWon
I bought the Autometer gauge mentioned by vdubdoug as well as the mounting cup ($20?). I mounted the gauge straight to the upper steering column cover. Very stable, visible, and cost effective IMHO. Here's pics:
http://www.welchco.net/minicrunch/DSC02332.JPG
http://www.welchco.net/minicrunch/DSC02333.JPG
Old 01-01-2004 | 10:01 AM
Scoutd's Avatar
Scoutd
SWEET!
how difficult was it to tie into the wiring harness? Or how did you make contact with power? :smile:
Old 01-07-2004 | 02:30 PM
Kotchie's Avatar
Kotchie
>>SWEET!
I just heard from the service manager at my dealership that the easiest way to tap power is from the cigarette lighter - you get both switched power and dimmable lighting and the wires are easily identifiable and reachable. Good luck!
Cheers,
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
08-19-2015 12:51 PM
Phantogram
08-12-2015 12:11 PM
pewx3
08-07-2015 03:34 PM
Quick Reply: Drivetrain Gauge mounting options
