Drivetrain OCC needed on 2011 MCS?
I anticipate taking delivery of my 2011 R55 later this month, and am planning my first mods. Reading the threads here it sounds like the 2010 and earlier MCS benefit from the addition of an OCC (or two) in the PCV system. I've heard the PCV on the 2011s is different, so has anyone done an OCC on a 2011 MCS yet? Does the 2011 still need an OCC?
Thanks!
Thanks!
The crankcase ventilation system is different!
Porthos,
I heard it was different so I checked Real-OEM and sure enough it seems the vent from the passengers side of the valve cover to the intake manifold is gone. At least it is missing in all of the photos and drawings. So I went to my local dealer and popped the hood of a 2011 MCS and felt around. The valve cover end isn't there, but some hose is attached to the location on the intake manifold where the old hose led. I had my hand down there and was trying to feel my way along, but it is too crowded. I wanted to whip out my tool set and remove the stock airbox, but I don't think the Mini of Annapolis folks would have appreciated that in their showroom.
I am interested in this because my understanding of PCV systems is that they need a "metered air" source and a recirculation exit. The BSH approach removes the recirculation exit and conversts the metered air source to and exit/source. I want to figure out if that is what the BMW engineers did on this engine. Or, did they meerly move the location of the crankcase end of the exit? Further investigation to follow.
Cheers,
Greg
Cheers,
Greg
Ryan,
Here is the diagram for the pre-refresh turbo-charged engine from real-oem.
Item 1 in the figure is a plastic hose with a heat resistant covering that connects the intake manifold and the cankcase as part of the PCV system. It runs under the intake manifold connections to the cylinder head so it is hard to see the connection at the low end.
I noted on the 2011 engine there is not a similar part listed and nothing is connected to the top of the passengers side of the valve cover. But, on checking I could feel something connected to the intake manifold where this hose would go. It felt like the same kind of plastic with a heat-resistant covering, but I couldn't see where it went.
If you could stick a mirror down there you could probably see what I am talking about. The question is "Does a hose connect there that is coming from somewhere else on the crankcase (as a vent), or is it simply capped off (or not there)?"
I hope this sheds some light on the question. If there is no hose, then the only PCV line is going from the driver's side of the valve cover (the small hole shown on the figure above) to the turbo inlet. It would then probably be a good idea to put a catch can in that line to keep oil vapor out of the intercooler.
Cheers,
Greg
Cheers,
Greg
Ryan,
Cheers,
Greg
Cheers,
Greg
Have a definative answer!
Thanks!
Thanks!
I was at my dealer today and talked to my MA (Sean, a really good kid). I took him to a 2010 and showed him the PCV system, then took him to a 2011 and showed him the visible changes. I asked if he would talk to the Head Mini tech and find out if BMW just deleted the passangers side line of the PCV system on the 2011 or if they simple chose a new route. Sean just called and said that the Head Tech said that BMW deleted the passanger side line completely and that his advice is to install a catch can on the one existing line. He also said that he has a 2008 and he put in the BSH catch can and dual boost tap port (the thing that blocks the passangers side line).
So the correct answer is - Go with the BSH way of routing the catch can!
Cheers,
Greg
To add another perspective, I recently saw the following in an email from the President of BSH Speed Shop regarding their OCC and the revised PCV configuration on the '11 MCS:
"We have plans to get a car in the shop the early part of 2011, at this time we are operating under the impression that a completely new hardware kit will need to be developed. We will be sure to update our dealers with our findings so they can tell the world."
Theirs may be an overly-conservative impression (not sure what would necessarily change from the existing BSH OCC design) but I thought I'd pass this along for everyone's benefit.
OK Guys,
Cheers,
Greg
Cheers,
Greg
on
Spoke to Mini tech...
I spoke to a Mini tech that I know to be very good and asked his thoughts on an OCC for my 2011 JCW. He told me not to do it because the cars that he has worked on with them installed have had problems arise with moisture in other parts of the engine. The guy is very trustworthy and works on these cars everyday and his recommendation was to go without an OCC. I plan on using this as my daily driver for at least the next 4-5 years and would like to do whatever I can to preserve the life of the engine. Has anybody else heard of this and can I get some second opinions?
