Drivetrain $1,000 Budget...
I had planned on doing the AP tune first, since I was under the impression that this would unleash more HP stock than an intercooler and CAI with the stock tune.
Is this untrue? Will an aftermarket intercooler and CAI with the stock tune make more power than an AP tune with all stock hardware?
Look, you can do whatever you want. But just from an engineering standpoint, by getting a tune, and upping the boost, you make more heat. The stock intercooler just can't deal with it, and after about 30 seconds of fun time, the intake air temp starts climbing, and you may be actually start making less power than stock. I haven't done any testing to actually look at the data, but I bet Adam and the boys at Alta have. And my little engineer brain thinks it's probably right.
No doubt the the Access Port is fun, (I've got the Jan tune with the Dimsport, effectively the same tune now, and the Alta intercooler), but, the longer you boost, the hotter it gets. Even with the stock tune. I feel pretty safe saying it would be worse with the stock intercooler.
question; is an alta port tune really noticeable to a layman? I've got an auto 09 clubman s; would it be something I could "feel" enough to smile about my investment?
I don't plan on going down any mod heavy route (like, a CAI is about as far as I went last car) -- if I had free cash, I'm the kind of person that would pay for the mini jcw tuning kit, so if you could compare it to that it would be helpful.
thanks!
thanks!
$1000? Access port for sure. NO HARD MOD can compare at all. All the hard mods together can't compare.
Second power mod should be an IC so you can crank it even more.
After that I'd be looking at suspension as you'll have lots of power.
yes, just the accessport alone will give a very noticeable boost in power. More power than the JCW kit.
NiKTaMeR
15
03-12-2008 07:34 AM
