Drivetrain Cylinder head swap
on
randy
on
I would RUN not walk from that shop . Our local shop would do it for $ 750 and no more than a day and a half . He is up here in the L.A area though. Johnnies Auto Clinic in San Pedro is the closest shop to you that I know personally but I am sure that there are others that know of a reputable shop in your area. My advice is to keep looking .
Randy
Randy
Most shops that "specialize" in a certain manufacturer wii work with you because they rely on that brands owners. Here's how it works. A typical shop bills on "flat rate" basis, which is generated by a "book" or "manual" of hours to charge for a particular job. This fig multiplied by the shop's labor rate (95 in this case) gets the price to you. Shops don't usually like the big jobs because they will make more money on the shorter faster jobs. Most mechanics can beat flat rate so they can bill more flat rate hrs in a week than actual hrs they actually work. They can usually bill 50-60 hrs in a week. Now here you come with a big job and if they're a fairly busy shop they aren't going to want to tie that tech up on a job that could be a potential problematic time consuming affair that only pays 20 hrs. So, they shoot you a big price and if you bite they have enough hrs added in to cover the tech not being able to make flat rate on the job. Then there's the dilemma of what book or manual are they busing? Factory manual, Chilton manual etc etc all will give different times for the same job. So, try and find a shop that specializes in Mini Coopers and relys on Mini customers for their livelihood.
Most shops that "specialize" in a certain manufacturer wii work with you because they rely on that brands owners. Here's how it works. A typical shop bills on "flat rate" basis, which is generated by a "book" or "manual" of hours to charge for a particular job. This fig multiplied by the shop's labor rate (95 in this case) gets the price to you. Shops don't usually like the big jobs because they will make more money on the shorter faster jobs. Most mechanics can beat flat rate so they can bill more flat rate hrs in a week than actual hrs they actually work. They can usually bill 50-60 hrs in a week. Now here you come with a big job and if they're a fairly busy shop they aren't going to want to tie that tech up on a job that could be a potential problematic time consuming affair that only pays 20 hrs. So, they shoot you a big price and if you bite they have enough hrs added in to cover the tech not being able to make flat rate on the job. Then there's the dilemma of what book or manual are they busing? Factory manual, Chilton manual etc etc all will give different times for different jobs. So, try and find a shop that specializes in Mini Coopers and relys on Mini customers for their livelihood.
Great explanation For the OP why don't you check out www.scmm.org which is our So Cal mini club. There are quite a few San Diego members and you could put up a post and ask for some local knowledge.
Randy
M7 Tuning
09-02-2015 09:05 AM
