Drivetrain If you have a stage 3 alta tune I'd like your opinion..
So, first off.. Thanks in advance for your input, this particular issue has been bothering me for a long while now... (About 5000 miles)
Ever since I installed my alta parts (FMIC, hot side boost tube, turbo back exhaust, and ap stage 3 tune with linear throttle) Ive been driving with my windows down all the time.. The reason for this is because:
1) When the AC is on I feel my car drive completely differently.. The throttle response is not nearly as touchy, I like it touchy... yes I am aware that the AC puts drag on the engine, but the difference is more than just noticeable.
2) When I come to a complete stop the rpm's will fluctuate by about a 200 rpm curve about every 4 seconds. This is not constant but more random..
At this point as it is coming up on summer time I am debating weather I should try out a RMW tune.. I know here in Florida it will be raining a bit more now..
Also on a side note, Id like to add that when I switched to the non liner throttle map the other day, I found my car to be un-drivable. mainly because my car was going all out at maybe a quarter pedal..
Adam
Adam
Alta Stage 3 tune
Contact Alta and explain that you have the idle issue. They will send you a tune with the fix. Also ask for the "super-linear" throttle settings in the tune and that you want this set to both the sport and non-sport button modes, this will give you the "touchy" throttle you are seeking.
I am aware that they have an idle fix I just have to get my build number off my AP before I email them.
About the throttle response, its perfect with just the linear throttle mapping, however once the ac goes on that goes out the window... to the point where when i drive my car as i would if the ac was off, it chokes every time i come out of first..
Youll be surprised by stage 3. Especially if you get all the parts on, drive it on stock map, then switch to stage 3... thats what I did and WOW... Yesterday I raced a Neon SRT4 with mods and it was dead even, we pulled maybe 6 or 7 times, and every time it was just dead on.. mind you that guy had no clue how to drive, bouncing off the rev limiter in every gear, but thats the great thing about our cars.. instead of starting a race at 5000 rpm, i start at about 3500 so even though they get a second jump on me, when their shifting im still goin hard!
The only one that I remember was 55 in third. But the rest, he just got up next to me while I was cruising and when I heard him downshift I hit third and went. I don't often race with first or second gear in order to conserve rubber on my tires. I won't break traction in 3rd unless I go over a bump in the road while at max boost. Except this one time, but I think that had something to do with the traction control failing because it was definitely on and I still lost traction nasty in 3rd passing someone.
07-16-2020 12:54 PM
08-21-2015 11:25 AM
