Drivetrain Heat Shield MOD
on
Heat Shield MOD
All,
I used the Stage 1 Alta tune and hit 19psi last night. After about 3 minutes my turbo was a cherry and it scared the **** out of me. I can't tell if I was running lean or what, but it was pretty scary. So I went back to the Stock tune and decided I needed to make a mod to keep that from happening again.
I had an idea to cut 1' slits in the stock turbo heatshield and add a metal fan with a metal blade to spit heat away from the turbo. The slits will be masked by the NM heat shield when it comes in, but will keep the turbo from seizing due to heat. I run Royal Purple oil, that helps but just isn't enough...
on
OK, Got the slots cut. Cut 3 on each side of the arch of the turbo. At higher speeds, the hood scoop rams air into the engine cabin, and it makes it way around the turbo's slots. I ran it hard and noticed when I poped the hood it was not nearly as hot as usual. It does not look pretty by any means, but if you put the NM heatshield over it, it will make it look more clean. I had not added the fan yet, but don't think I will need it at all. What I have done so far is helping imensely. Highly recommend this mod, if you have a 10mm wench, cut off wheel, and 2 hours.... (1 hour for getting the damn shield off....)
on
I'm not sure cutting holes in your turbo heatshield is a good idea.
If you want to increase the air flow and cooling to the turbo, have you considered this mini challenge part. Sits underneath the scoop and directs airflow to the turbo. It works well.
http://www.minigenuineparts.co.uk/mi...lengeVent.html
or alternatively try the new mini challenge bonnet scoop
http://www.minigenuineparts.co.uk/mi...engeScoop.html
I haven't tried this one myself. Pretty pricey
Robbo
Robbo
All,
Heat is good for the turbo keeps exhaust gases moving quickly, improves turbo response and retaining boost pressure or else they wouldn't sell turbo blankets for turbine housings to aid in trapping heat which also keep the engine cool. Ceramic/Thermal coatings as well.
OP stated hes running a higher boost "staged" tune, also for 3 minutes which im sure we can conclude it was hard. These ecu's if lean conditions exist will throw codes, also a " clogged "catalytic converter, which i have yet to ever see with my own eyes only was really prevalent in the years of leaded fuel. For a 2007 to have a "clogged" cat would mean new age technology has failed us... and i highly doubt the turbine would glow read without the egt's of under boost loads.
Sc00terbum
09-11-2015 09:07 AM
M7Speed
09-04-2015 10:47 AM
M7Speed
R58 :: Coupé Talk (2012+)
09-03-2015 07:29 AM
