Drivetrain Catless Downpipe and AP
#52
Standard MCs exhaust diameter
Just wanted to add some knowledge to this thread. The stock exhaust from a MCs is as follows:
DP to the front of the flexim: 63,5mm or 2,5"
After the flexim till in front of the resonator: 60,0mm or 2,36"
After the resonator till in front of the back box: 55,0mm or 2,17"
That is the reason why a 63,5mm/2,5" system from turbo back gives such good gains. And of course removing the catalyst gives you a free flowing system with high potential.
#53
Sorry Mike, I should have explained it better. This is they dyno sheet:
Shows that this JCW with our 3" turbo back exhaust with 2 high flow cats system made power by simply removing one of the high flow cats! This shows that even with a 3" system with high flow cats, the JCW benefits from higher flow.
So far just about everything is theory, since no one that I know of has done a back to back test of a 2.5" system on a 3" system. But I'd bet my sandwich (that's a pretty big deal because that's pretty much my whole lunch) that the car with the 3" system will make more power.
This does not prove that a 3/4" diameter garden hose, hooked up to the same 1/2" spout does not flow at the same rates.
Apples to oranges. All it showed was the cat is VERY restrictive (which I think we all agree on)
GAT
10-04-2015 07:27 PM
