Drivetrain AEM Cold Air Intake on a N18
I tried doing a search, but just couldn't find what I wanted. Is there any reason the AEM CAI wouldn't work on a N18? I'm subscribed to the AEM thread all about this intake for the 07-10...but it's a long thread and when I viewed it...I couldn't find out WHY this wouldn't work with a 2011+.
I was told the only difference in the OEM intakes is the 2011+ have a harder plastic pipe that doesn't need to be replaced like the 07-10. If this is true, the AEM should still work...I'd just be getting a fancier pipe that I don't necessarily need. Since the intakes I'm looking at are around $250 anyway, an extra $100 seems like a deal for so many extra parts. And yes...I like to dress up my engine bay. LoL.
I apologize if this has been asked 100x...I just couldn't find the answer.
Before you buy one, talk to whoever you buy it from to ensure that they are selling the "updated" design. They had some issues with the "scoop" piece deforming due to heat from the turbu and the design of the piece. They are revising the design to correct this. They are also the heat shield and gasket on the top of the air box.
something ive noticed about this intake is the same thing with NM's they sell a different kit that doesnt include the charge pipe option for 2011+ just the silicone elbow at the end. which would lead me to believe theres a difference in the pipe and i think its on the other end... i could be wrong i looked at getting this intake as well anyone with any updates?
So did you install this yet?
Looking for your feedback.
Talk about disappearing lol
I was looking at the instructions, and I think the stock inlet tube can be cut, and just purchase a silicone piece to connect it to the aluminum pipe and you're set.
The reason for cutting the stock inlet tube is because of that sensor on it. I'm considering doing this but just don't know if the mounting holes for the intake box are any different from the N14 to N18?
Yes, cut the grey metal tube to only use the 90 degree bend.
Be sure to measure the length before doing so, or you can cut too much off.
The heat shield will also be unusable, unless you remove the valve cover.
I spoke to Ken from AEM, he said August 28 to get the n18 stuff in. He said the air boxes are taking a while to manufacture.
They changed up the design to yield better results then the current offering for the n14s.
Any updates? Hopefully it fits my new GP without issue.
Crazy timing, I just spoke to Ken about 30min ago.
I was told they should be getting the first articles in by this Friday/early next week. If the fitment goes well, they'll hit shelves in 2 to 3 weeks max!
Cannot wait! I've been sitting ever so patiently lol.
It should fit your GP no problems. It is an N18 after all !
