Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
#579
There's a few places around me in the Chicago-land area that will do dyno pulls for about the same price. I plan on doing some pulls as soon as I get the FMIC and Stage 2 done. I'd be interested to compare numbers for sure.
#580
Hey Tony, here in Michigan we don't get rarely to no dynos. I should come to Chicago this summer since I'm only like a three hour drive to get there. I'd definitely be interested in a dyno!
#581
#583
When I get this put together, I can make the information available and anyone on NAM who wants to show up could benefit from the discounted price.
#584
That does seem low for a stage 2 with DP and IC. That means stage 2 without DP would be even lower, and stage 1 with DP only even lower, and with neither, uncomfortably close to stock. It must be worse for those with an auto.
This is exactly what I was curious about though. Maybe I missed something but when those numbers were posted I didn't see anything about a DP, only the necessary IC with stage 1 and 2. I wonder what mods are implied with Renntech's tune.
I agree that it does seem low...but I understand Jerry's stand point and his comment about saving up for a clutch lol.
I'd love to get a custom dyno tune but with these N18's it just makes it a lot more difficult.
When I get my car back from AEM on Friday I might go ahead and just get the tune.
First I have to see if my ECU meets the cut off date that they can tune =\.
Anything after build 3/12 they can't do yet because that's when the new encryption code was put in place by BOSCH.
#585
#586
Out of curiosity, you have the Evolve tune correct? What stage did you go with?
#587
I've decided to go with a Renntech tune for my '13 JCW Coupe AT. I'll do this in a couple of weeks. Would you guys think that doing the mods after the tune is ok? I am doing the Forge FMIC, Akrapovic DP, Forge Recirc valve after the tune. Also, contemplating if I need a hot side intercooler pipe (NM or Forge)? Comments?
#588
#591
Okay then, here's the answer you will probably be given by the tuner:
You can not have a tune that requires a FMIC without actually having the FMIC. No getting it later, etc. If you choose to wait on the FMIC, get tuned for the stock one first, then send it back in later.
Timings are heavily adjusted due to charge air temps.
The Akrapovic DP can be added after the fact, as it isn't taken hugely into account on the tune. It will, however, net you gains later due to the free-er flowing setup. They will tune the CEL out if you let them know you're going that route.
The use or addition of the Forge BPV (and I have used one for over 2 years) is really at the discretion of the tuner. It offers a bit more reliability, and the ability to hold higher boost levels (beyond anything our turbos can put out). The BPV on the 2013 JCW has been tweaked, so I am personally holding off installing mine until I hear further.
Check your hot-side pipe - the JCW usually does not have the muffler on that pipe, and is a straight (un-kinked) design. I know for a fact my 2013 has a large, smooth, muffler-less pipe. No need for a replacement pipe.
No use or gains in changing the cold-side pipes.
Perhaps that's what you were looking for...
#593
If it were me, I'd do the mods with or before the tune.
I stopped by HG Motorsports yesterday, a local RennTech distributor. From what I gather, RennTech's tune is pretty much a canned tune. But they do ask you to list the mods you have in detail, ostensibly because they make small tweaks to the tune file. If true, then a customer who reports a bone stock MINI may get a different tune file than one who reports an upgraded FMIC on the car.
I would just do the mods ASAP if cash allows. Had I a R56/57/58/59, I would do the following before tuning:
1) Forge or Helix FMIC
2) Akrapovic turbo-back exhaust
3) DoS or AEM intake
4) Forge diverter valve
Done.
Done.
#595
Just got back from Helen Georgia on Sunday (MINI event called Helenblitz). The drive up was through pouring rain. I seriously had to watch the increased torque from the stage 2 tune. The day before going up there, I almost went off the road into a tree when torque steer hit while spinning wheels (wheel) in third gear. This has convinced me that I NEED a limited slip differential!!! On 15 March, Way will be installing a Quaife LSD in The Dread Pirate. That FINALLY will be the end of the "major" mods for quite some time (unless Koni's call my name too loudly!).
#596
Jet127, it took me 2 years to put The Dread Pirate together to the point where I felt comfortable for... and felt the need for a tune. It helped that there wasn't an N18 engine for a good portion of that but I would have waited anyway because I wanted everything in place. I wanted the best breathing MINI that could take the most advantage of a tune as I could have. The last part of the plan was the WMW (JCW?)Turbo Exhaust Manifold. What I am saying, is don't rush. There is no need to. I had extreme amounts of fun and two MotD's without a tune. Make a plan for upgrading your MINI's parts and pieces and carry it out before worrying about a tune.
#597
Every I do something to the car, someone else in the club had to do me one better. So I have to do them one better in return. And the modification cycle perpetuates. Haha
Check the sig, that's all in the 8 months / 16000 miles since I rolled her off the showroom floor. LOL
#598
#599
No car club nor peep pressure, just a plan. The following done in two years/22k miles (the big list):
Aesthetic Creations Black Door Handles
Akrapovic:
Down Pipe
Delete R
Alta Blow Off Valve Spring Upgrade
Craven Stubby antenna
Defenders of Speed CAI
Forge FMIC
Helix Short Shift Kit
Hella Black Magics (w/HID upgrade)
H-Sport Rear Camber Links
Mini Fini Black Intake Scoop Grill
NGK Cold Heat Range Spark Plugs
NM:
ECU Tune
Aluminum Billet Tie-Bar
Discharge Pipe
Titanium Heat Shield
Torque Arm Insert
Shifter Assembly Box Cover
Quaife Limited Slip Differential (on 15 March)
TSW:
Performance Springs
19mm Sway Bar
X-Brace
Vinyl Styles: (all black out except JCW grill trim)
Headlight/Taillight trim
Gas Cap
Side Markers (smoked)
Boot Handle
Belt Line
VIP Custom:
Down Pipe Back Exhaust (last 1/4 powder coated black)
Driving Light Brackets
Whalen Shift ****
WMW:
Stainless Steel Brake Lines
The only thing that I really have left is Koni's... Sure...
Akrapovic:
Down Pipe
Delete R
Forge FMIC
NM:
ECU Tune
Discharge Pipe
Torque Arm Insert
TSW:
Performance Springs
19mm Sway Bar
X-Brace
Gas Cap
Boot Handle
Belt Line
VIP Custom:
Whalen Shift ****
WMW:
#600
