Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
#676
Sorry if that came off worse than I meant it -- was just supposed to be informative to others who read into the Evolve post.
Don't forget NM on the 2011/2012s - very viable and a great tuning solution.
The '13 ECUs removed some of the JTAG, including the VCC point. Kind of a mystery as to how the tuners are getting in anymore (NM doesn't have the ability yet, among others).
I'll PM you about the CAI!
#677
Keepin' my eyes peeled for the PM. Good to hear from you, Theta.
#679
Ok, so I plan to go straight to NM stage 2...since it has about the same gains as the Renntech tune but for only $500...also to Rob I have a DDM RIS and I like it but I want to switch to a DoS. So I was wondering what the Dyno numbers quoted for Evolve were since there are none posted on the first page and I don't see any anywhere...if the numbers are significantly more than a stage 2 NM tune I might be considering them...
#681
You might be missing the point with the boldfaced part.
ETG claims that N18 cars with high-flow downpipes will have overboost issues on their tune. Whether that's right or wrong, ETG thinks its an issue. If their right and it is an issue, then that's a bummer for those of us with DPs. If they are wrong and it is not an issue, then you just had your car tuned by a tuner who is mistaken about a fundamental aspect of tuning. That, too, is a bummer.
I mean dont get me wrong, it does seem king of unsettling that they would develop a tune that causes overboost issues at all, and push numbers that other companies cant (or maybe wont?).
In the end I dont have the kind of money to be taking risks with a tune for extra hp, and will probably end up going NM unless there is some crucial piece of info that would change my mind. Or if I get the money to just drive an hour to Renntech
#682
#683
The answer is no, around 185. And I wouldn't get a catless down pipe either, unless u can open source the tune. You'll run too rich, overboost and cause more carbon build up and the O2 sensor won't read correctly unless you go wideband
http://www.nm-eng.com/media/attachments/269_r56dyno.pdf
#684
some quotes from my phone conversation with Jags from ETG:
"the only thing we sell is the tune, we do not sell parts"
"we have developed an N18 tune that gives you +40 hp and +60 torque with the only mods required being an upgraded FMIC and a drop in high flow panel air filter or other closed intake ... making our tune the best value to the you"
"a dp back aftermarket exhaust has little effect on the tune, but sounds nice"
"if you want to use an aftermarket DP, i will need to adjust the tune to avoid a potential overboost condition and CELs, but the gains will be the same as with the stock DP"
"we have seen no problems with the stock diverter valve, but if you feel the need to upgrade we suggest the forge piston style recirculation valve, do not use the blowoff version"
"there is no reason to remove the intercooler resonator unless you want to hear the noise"
hope this clears up the ETG tune situation
i was going to get a renntech tune, but after speaking to Jags, a dry foam airfilter, a tyrolsport FMIC, an ETG tune and i am done
scott
EDIT:
Jags confirmed he can tune ALL N18 ECUs
scott
EDIT:
#685
scott
EDIT:
scott
EDIT:
Bmwr606, when do you think you are gonna make the jump?
#686
illinios has an "exemption clause" for the emissions test ... have to spend $450 trying to clear the codes, but the catch 22 is it has to be worked on by a "certified repair shop", not by the owner
it's in the shop now ... fate unknown ... bill unknown
should know monday, then i will know when i can upgrade the cms all4
scott
#687
scott
EDIT:
scott
EDIT:
This is very helpful info, thank you!!
#689
#691
Looks like Evolve is out. Here's the email I got back from them:
Thanks for your email.
We are unable to tune the late MINI due to the block you have mentioned.
Best Regards
Imran Arshad
evolve automotive
www.evolveautomotive.com
UK: 0871 231 1020
Int: 0044 1582 584 000
Best Regards
Imran Arshad
evolve automotive
UK: 0871 231 1020
#693
Just spoke to Jags,
I am sold. I am going to him, ETG. Sometime in april I will have his tune on my car. Considering I don't need a silly DP like others have suggested, and a DV.
I will install my exhaust, sell my intake and go back to stock, and install my FMIC too with the hot side and I am set.
I definitely consider anyone with a 2012-2013 to go to him, he told me those can be tuned. Good luck guys!
#694
I agree with everything you've said except the "silly DP" comment... that's a bit offensive.
This tuner doesn't like to tune with it, but it's an obvious restriction that has been proven over years of data collection (since the R56 launch in 2007) to be a point of power loss.
Replacing the downpipe is, to the contrary, not silly at all. This tuner seems to have an issue with his maps not being friendly with the higher flow. There's nothing wrong with that, so long as you're comfortable with the rest of the tune. However, to each their own!
#695
#696
I'm not going to start a war here, I'm just not on the side of calling an obvious restriction removal "silly".
Numbers are wonderful, but we have so few dyno sheets/results that anyone can claim just about anything these days, and that's a fact.
NM had a tune running so hot (race-only 93-100 octane) on mine that it was nearly stupid - it also caused issues with the Auto, etc. Excellent power, but at a hell of a price. They have since discontinued that offering. I applaud them for taking it that far with me - we were at +80ftlb at the time.
Never in my life (or as a tuner) have I seen a turbo application NOT benefit from a downpipe/catalytic converter swap. I'm not a fan of test pipes, but it's simple science that backs the support of the downpipe swap.
Again, I'm just basing off fact. I don't especially care what numbers get thrown around. Line up 3 JCWs all tuned with the different tunes, same parts, and on the same day, and we'll have a fair set of results.
However, since this is never going to happen, this is one big d**k measuring contest without a ruler.
#697
Theta sorry if I offended you or anyone else about the DP. I wanted one and I still may get one if this guy ETG tuned with a DP works out. He's basically their test dummy. But it's funny how NM had trouble with making an auto produce more power but ETG confidently said they've done autos with 40hp/60tq without any issues.
Again if this guy with a MINI runs the DP with no issue, I will eventually test it out myself but I will be selling my intake soon for those who want it, check the marketplace soon.
#698
I don't think you offended anyone.
.....just be careful with these folks. Almost every tuner has been able to get better numbers when a customer moves to something higher flowing.....so the fact that these guys are saying it doesn't do much to have one is enough to throw caution to the wind.
You seem to be getting quick responses from them...ask them why the car would overboost from a high flow or catless DP with their tune.
Tuners who have worked with those (DP's) have never reported the issue ETG is.
#699
It's okay - I know your heart was in the right place, just throwing a differen perspective out there one why DPs are important.
Every tuner is different, and they have their own maps that they're happy with. I think NM can squeeze +50tq out of a stage 1, but again... the numbers are arbitrary.
As far as the intake goes... I absolutely love the sound, but the stock intake with a quality filter is a true CAI that works VERY well. No shame in going back to that!
