Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
Old 03-29-2013, 03:58 PM
RobMuntean's Avatar
RobMuntean
RobMuntean is offline
Originally Posted by Jaremy Cheetwood
From my experience MINIs do not have an "oil cooler" stock..
This is a real oil cooler for an R56/R56LCI:
http://www.sneed4speed.com/mini-oil-...y-sneed4speed/
The car has a heat exchanger in the oil system that helps with heat, but that is not something you would swap out.
#4 in the diagram is the stock heat exchanger.
EDIT:
I called Renntech to discuss the oi cooler mentioning. He said they recommend one to all higher hp (220WHP+) R56's since it is well known the R56 pistons crack and fail from heat commonly. Oil cooler helps reduce that problem.
My experience is 109K miles, 60k tuned and I have good compression per my recent test. So its all in how you maintain and drive your car. If you plan to track the car or drive hard on runs constantly its not a bad thing to get, but stock we do not have one.
RennTech will do custom dyno tuning as well for those who are local and willing to pay for dyno time. I would do this if I was anyone near them. Dyno tunes gain 20-30WHP more on a R56 than the canned tunes do. After talking with them for a good 30 mins. on the phone I would choose them out of the options I have seen provided thus far (since RMW isnt an option). Plus RennTech is known for having beastly tunes for the AMGs.
Cheers.
RennTech and brentuning are both the best. NM is good too can't hate on them, even if they aren't as good with automatics. ETG/Smokey's is my last resort if MINI dynamics doesn't come out with a OBDII.
  #952
Old 03-29-2013, 04:42 PM
Melangell's Avatar
Melangell
Melangell is offline
Question is... Do MINI owners need an extra oil cooler?
  #953
Old 03-29-2013, 04:49 PM
Melangell's Avatar
Melangell
You ETG'ists have proven nothing except that you are wrong.....
  #954
Old 03-29-2013, 04:51 PM
Melangell's Avatar
Melangell
If later I need an oil cooler... I will buy one.
  #955
Old 03-29-2013, 04:52 PM
Melangell's Avatar
Melangell
  #956
Old 03-29-2013, 07:29 PM
RobMuntean's Avatar
RobMuntean
Wrong about what? I'm just curious why you are kind of attacking them? I'm personally not getting their tune but if they seem happy with it then why not just let them discuss with others about their car issues or whatever they may discuss.
We know your pro-NM tune so we understand why your sticking to them but for some of us, we choose not to have a tune with issues on automatics such as surging. How come other guys in N14's automatics got to have high numbers but they had no surging issues? I am doing my best to find alternatives for us. It's easy for the manual guys to get a tune obviously. I learned my lesson to never buy another automatic unless I buy a mini van lol.
As for an oil cooler, I wouldn't even buy one unless I was tracking the car hard. If you do it once or twice you'll be fine without it. Maybe Theta can touch on it since he's working with RennTech.
  #957
Old 03-29-2013, 10:15 PM
Hujan's Avatar
Hujan
Hujan is offline
Cheers.
Did they say anything about doing a remote dyno tune? There is a RennTech distributor here in San Diego with a dyne. I'm wondering if they wouldn't be able to make it happen.
Also, I've often thought an oil cooler would be a good investment no matter what. According to my ScanGauge II, the oil temps run ~220 F. That is pretty f'ing hot, kids! I do think that things to reduce heat (FMIC; oil cooler; meth kit; White Lightening coating on exhaust manifold and down pipe; unobstructed grilles) will greatly reduce the odds of engine failure and prolong engine life.
  #958
Old 03-29-2013, 10:46 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
when did the scan gauge add oil temp? last time i talked to them they told me no oil temp on minis since there is no oil temp sensor onboard, only oil pressure
are you reading water temp? 220F water temp is normal for most recent vehicles
scott
  #959
Old 03-29-2013, 10:50 PM
RobMuntean's Avatar
RobMuntean
I got the oil temp too on my scanguageII. I guess you didn't send your scanguageII to that guy in Arizona or something like that lol. I forgot his address but there is a thread on here where you can send it in for the latest software.
  #960
Old 03-29-2013, 10:53 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
i passed on buying it when i was told no oil temp
i bought prosport 45mm (1.75") gauges instead
oil temp
oil pressure
water temp
boost
volts
scott
  #961
Old 03-29-2013, 11:20 PM
RobMuntean's Avatar
RobMuntean
Shame on them who told you that Scott. I pretty much have volts, oil temp, engine temp, and water temp showing.
  #962
Old 03-29-2013, 11:32 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
i called direct to linear logic in az
talked to tech support because sales did not know
was told no oil temp because the mini DOE NOT HAVE AN OIL TEMP SENSOR only coolant temp
scott
edit
the ultra gauge people told me the same thing, no oil temp because the mini has no oil temp sender
  #963
Old 03-29-2013, 11:34 PM
RobMuntean's Avatar
RobMuntean
scott
WOW...idiots. Sometimes I swear if someone doesn't know something, ask. I'm sorry they gave you false information Scott.
  #964
Old 03-30-2013, 12:01 AM
Hujan's Avatar
Hujan
Hujan is offline
Reading around BrenTuning's site, they do seem knowledgeable. I sent them an e-mail. If they check out and MINI Dynamics doesn't, I may be giving Bren my biz. Fingers crossed.
  #965
Old 03-30-2013, 07:23 AM
RoyalCooper's Avatar
RoyalCooper
RoyalCooper is offline
RennTech In San Diego
Are you referring to HG Motorsports?
http://www.hgmotorsports.com/index.php/tuning
I've had no contact with them but their website seems to touch on a lot of good points. Have you spoken with them at all?
  #966
Old 03-30-2013, 07:25 AM
RoyalCooper
So no RennTech for you...even if you can get a dyno version in your backyard ? Where would you go for BrenTuning ?
  #967
Old 03-30-2013, 08:29 AM
Hujan's Avatar
Hujan
Hujan is offline
I am referring to HG Motorsports. I've been there twice and swapped e-mails with one of their reps, Blake Warren, many times. He's a very good guy and they seem like a good group all around.
Are you in San Diego?
Not necessarily. I am liking what I'm hearing for both. The only thing that I don't like about RennTech is they push the power from the tune up the powerband on an automatic so that you don't get the tune until 4,000 RPM. I'm not sure I'm comfortable with that idea. I freely admit I might not be understanding how that feels, but it seems to me that for a daily driver that spends little time above 4,000 RPM, this would effectively be like having no tune at all. Couple that with the ~$1,000 price tag for the tune and it doesn't exactly whet the appetite.
If Bren can get me good power and torque lower in the power band and for less than RennTech, it would be hard to pass up. On the other hand, if RennTech can dyno tune to tailor it to my car so I can get more out of my mods and maybe find a way to squeeze power into the lower range of the power band, I'm game.
  #968
Old 03-30-2013, 08:41 AM
RobMuntean's Avatar
RobMuntean
BrenTuning I believe is in Maryland.
I asked him if I could do a dyno but he said it could take all day to work on the ECU since mine is an automatic, and that the next day he could do a dyno, so I don't know if I can waste two days, possibly three. It would take like 7 hours or something to get there from my house.
I like BrenTuning and Smokey's Dyno so far. Hujan, I say we wait to see what MINI Dynamics has to offer.
  #969
Old 03-30-2013, 08:45 AM
Hujan's Avatar
Hujan
Hujan is offline
I think Bren is in Massachusetts. (MA = Massachusetts; MD = Maryland)
I agree re: Mini Dynamics. I'll give them some time to see what shakes out. I would love to have a handheld and tune (or de-tune) at home. But if they start pushing the product announcement back, I'll probably lose patience.
  #970
Old 03-30-2013, 08:50 AM
DKIKK77's Avatar
DKIKK77
DKIKK77 is offline
I have a renntech tuned automatic and I don't have to wait til 4000 rpms to feel the power. The peak torque is around 2500 rpms. My car was dyno tuned at their facility so that may be a difference. My dyno chart is in my gallery if you want to see it. I rarely even hit 4000 rpms in normal driving.
  #971
Old 03-30-2013, 09:01 AM
MINI4LYF's Avatar
MINI4LYF
MINI4LYF is offline
Wow 194whp and 241wtq? And on an automatic? I wonder what they can do on a manual! RennTech might take my cash... Waiting on some manual stage 2 NM dynos to compare. Also waiting for what MINI Dynamics has in the works.
  #972
Old 03-30-2013, 09:02 AM
MINI4LYF's Avatar
MINI4LYF
MINI4LYF is offline
Btw, what are your other mods, DKIKK77?
  #973
Old 03-30-2013, 09:08 AM
DKIKK77's Avatar
DKIKK77
DKIKK77 is offline
At the time of the tune just a k&n panel filter and nm cold side pipe. In the next month or so Ill install the fmic, downpipe, and exhaust and have it retuned. They said to bring it back after the fmic and/or downpipe so I might as well do it all at the same time.
  #974
Old 03-30-2013, 10:53 AM
RoyalCooper
I'm in Escondido actually. Their website gave me the impression that they knew their sh*t and were very professional.
  #975
Old 03-30-2013, 11:04 AM
RoyalCooper
What A Mini Wants
I’m looking for (as I think most of us are) to find a reasonably priced option that includes:
Dyno adjusted software re-maps of boost pressure, ignition timing, air fuel ratios, throttle response and rev limiter (manual trans) based on current mods on the car.
All done close enough (3 hour drive) to be able to get hands on customer service as needed.
Add to the checklist:
• Factory maps changed not redirects.
• RSA encryption and checksum blocks intact.
• Original file and P-Chip file saved.
• Only one performance file required for different octane, software will adjust.
• Tune file utilizes factory flash updates which normally comes with 'fixes'
• Completely reversible, zero physical modifications
• Retains all of the factory safety protocols
• Free lifetime upgrades and free re-flash back to stock programming
• 100 percent compatible with all diagnostic software
(most of the above are direct from NM)
Of course put all that into our own personal OBDII device that we can use to try various maps and ultimately put back to original stock as needed (dealer visits & smog tests).
Pricewise somewhere between the NM $500 mark and the $900 we expect to be under with our own OBDII access.
So there you have it; how close can we get?
And Oh, I forgot to mention...it should be available within the next week or so.
So hop to it Easter Bunny ...by the way you may need to call in the Tooth Fairy and any Leprechauns still lurking around, but definitely not Santa and the Elves (we can’t wait that long)
Quick Reply: Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
