Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
Old 08-24-2013, 12:01 AM
RobMuntean's Avatar
RobMuntean
RobMuntean is offline
Originally Posted by spooler
Is it recommended to swap the spark plugs? I am currently running stock, what are the recommended spark plugs to buy?
Terry told me NGK 5992. Like I said I will find out Tuesday to see how the car runs. Right now she's pulling harder and harder by the miles. It's incredible when I used to drive in 50mph zones, the car was running up to 55. Now she wants to go faster and easily reaching 65mph.
  #2002
Old 08-24-2013, 12:51 AM
NewCooperFanatic's Avatar
NewCooperFanatic
NewCooperFanatic is offline
I'd be very careful boosting 18lbs if you aren't running meth or a higher octane fuel.
  #2003
Old 08-24-2013, 06:18 AM
bmx045's Avatar
bmx045
bmx045 is offline
I thought the jb+ was to be used on a bone stock car? 1 step colders wont hurt but i think he's been doing r&d on a stock car, as well as on crappy cali 91 octane. i think there wouldn't be a problem running stock, if you have 93 oct available for certain use that.
  #2004
Old 08-24-2013, 07:47 AM
RobMuntean's Avatar
RobMuntean
No you don't have to run it with colder plugs, but I want to because with most tunes it'll be run the car more smooth IMO. Plus, I'm at 55K miles, so I think it's time for new plugs since I'm replacing the valve cover next week.
  #2005
Old 08-24-2013, 08:04 AM
Hodaka's Avatar
Hodaka
Hodaka is offline
I have Chevron 93 available here. Most stations have good 91, better than the California 91, from what I've been told. Apparently the additive package in Cali gas is less than stellar or something?
- Correction: Chevron 94 - filled up today.
  #2006
Old 08-24-2013, 08:10 AM
NewCooperFanatic
Yea, we have crap gas lol
  #2007
Old 08-24-2013, 08:15 AM
Coop-a-Loop's Avatar
Coop-a-Loop
Coop-a-Loop is offline
91=91 no more no less
  #2008
Old 08-24-2013, 08:45 AM
NewCooperFanatic
Problem is no 93 readily available at pumps =(
  #2009
Old 08-24-2013, 08:58 AM
ra2fanatic's Avatar
ra2fanatic
ra2fanatic is offline
meth is not necessary to run 18lbs boost. i was running stg3 cobb ap long before i added meth
  #2010
Old 08-24-2013, 10:00 AM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
93 everywhere in TX. I prefer Chevron.
  #2011
Old 08-24-2013, 10:01 AM
wzabrouski's Avatar
wzabrouski
C'mon. I know some of you for these bad boys installed.
  #2012
Old 08-24-2013, 12:07 PM
NewCooperFanatic
Guess I'm just being over cautious about knock suppression lol
What boost were you running without the meth?
I ask because your car runs great, so obviously no negative side effects from your previous setup.
  #2013
Old 08-24-2013, 12:30 PM
KilmerPT's Avatar
KilmerPT
KilmerPT is offline
Are there any 2013s in the JB+ test group, just curious.
  #2014
Old 08-24-2013, 12:40 PM
NewCooperFanatic
Terry's car is a 2013]......would he be counted in the JB+ test group?
  #2015
Old 08-24-2013, 04:00 PM
RoyalCooper's Avatar
RoyalCooper
RoyalCooper is offline
I'd say yes he would...but he's not the only one
  #2016
Old 08-25-2013, 03:17 PM
ayk07's Avatar
ayk07
ayk07 is offline
Can tool is not really required right? i don't need shiting lights or numbers on how much boost is running, yet at least. i want to get the jb+ and just plug it and drive.
  #2017
Old 08-25-2013, 03:24 PM
pidge1114's Avatar
pidge1114
pidge1114 is offline
  #2018
Old 08-25-2013, 03:51 PM
jomama's Avatar
jomama
jomama is offline
Originally Posted by pidge1114
Correct, JB+ is meant for plug and play. CAN is for tinkerers who want flashing lights and dancing needles.
and to read/delete codes, as well as to keep CELs from coming on from aftermarket DPs.
  #2019
Old 08-25-2013, 06:57 PM
spooler's Avatar
spooler
spooler is offline
Put ~100 miles over the weekend on JB+. It does seem to take ~50 miles to reach its full potential. No issues so far. The car just wants to go faster and faster. Pick up seems a lot smoother now. No matter what gear you are on, once you press the pedal, the car just comes to life.
At the moment I am running a mix of 100 octane and 91 octane in ~1:3 ratio. Contemplating if I should switch back to all 91 or keep it this way($8/gallon for 100 :( ). Would like to hear from you guys what do you think. BTW this is cali gas.
  #2020
Old 08-25-2013, 07:53 PM
RobMuntean's Avatar
RobMuntean
Agreed same here, took about 50 miles to truly kick in. Plan on using 94 sometime this week and Tuesday I'm changing my spark plugs to NGKs. We'll see how the car runs.
  #2021
Old 08-25-2013, 08:22 PM
Brandonpt's Avatar
Brandonpt
Brandonpt is offline
I was putting some 100 octane fuel along with 93. I noticed however I lost the kick pretty quick. I think the 100 octane precipitates and the car burns it first. Is it just me or have do you notice a decline in performance as well?
  #2022
Old 08-25-2013, 08:25 PM
gerry2153's Avatar
gerry2153
gerry2153 is offline
JB+ . . . what will it do on an S with a JCW tune ???
  #2023
Old 08-26-2013, 09:50 AM
Terry @ BMS's Avatar
Terry @ BMS
Terry @ BMS is offline
It depends on the intake temperatures and mapped timing advance. As far as the JB+ does I would not run any higher than the default setting on 93 octane. In some cases on 91 octane you may need to go a bit lower. But that is still being evaluated.
  #2024
Old 08-26-2013, 09:51 AM
TerminalVelocity's Avatar
TerminalVelocity
TerminalVelocity is offline
Tag for exciting N18 info!
  #2025
Old 08-26-2013, 02:45 PM
Exhaustdd's Avatar
Exhaustdd
Exhaustdd is offline
JB+ arrived today, should have the adaptation miles done by tomorrow afternoon. Will give feedback asap.
2013 R56
Quick Reply: Drivetrain The Always Up-to-Date Thread on Tuning 2011+ (N18) MINIs
