Drivetrain o2 sensors replacement and check engine light staying on
There are a lot of instances where the correct sensors do not work correctly unless they are OEM sourced. Why? I don't know and I have not seen an explanation. But I have seen the problem described more than once.
Rich
If you bought aftermarket Bosch O2 sensors, they will plague you with engine code issues. You need the NTK OEM equivalent sensors. Read more here: https://www.northamericanmotoring.co...r-install.html.
Drivetrain Help on MAF Sensor Clip - Cannot Remove
Motown
04-20-2018 09:31 AM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
