Drivetrain How Can I measure IAT?
Old 03-15-2004, 09:53 AM
Super_MINI's Avatar
Super_MINI
Super_MINI is offline
Just wondering, I thought it would be really cool to install a guage pod off of my tach that showed Boost and IAT. Can I get IAT easily after the intercooler? Does a probe already exist that I can get temps from or would I have to put one in? The ECU must measure IAT at that point doesn't it?
I would like to measure/monitor IAT with the 15% pulley on track days and then see what it's measuring with the 19% pulley then with air diverter and upgraded intercooler.
_________________
Old 03-15-2004, 10:15 AM
Trippy's Avatar
Trippy
Trippy is offline
Old 03-15-2004, 12:20 PM
caddman's Avatar
caddman
caddman is offline
there is another one by SP Eng. thats really cool it will do pre and post intercooler temps as well as display the diffrence(helps you get your effecientcy numbers)...and its cheeaper than the others i have checked into...
Sp engineering temp guage
Old 03-15-2004, 12:28 PM
fueledbymetal's Avatar
fueledbymetal
fueledbymetal is offline
I was interested in something like this as well, but I wonder if it would be cheaper to get a PDA and some sort of pocket logger. I'm not sure if this would allow you to read values real time though.
Old 03-15-2004, 12:55 PM
Super_MINI's Avatar
Super_MINI
Wow, that looks sweet. Thanks for the link Caddman.
Does anyone know where the ECU gets intake temps from?
Old 03-15-2004, 01:14 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
andy@ross-tech.com is offline
Intake temps for the ECU come from the TMAP sensor in the intake manifold. It measures both temperature and pressure.
I just picked up one of these for $25:
http://scientificsonline.com/product.asp?pn=3105400
We'll see how it works. I'm gonna install it in a spare rubber intercooler connector.
Old 03-15-2004, 01:50 PM
caddman's Avatar
caddman
caddman is offline
did you get the green goo to?
Old 03-15-2004, 02:11 PM
andy@ross-tech.com
No, the jerks must have forgotten to include it! I'll make myself some Mojitos when I install it.
Old 03-16-2004, 08:34 AM
MrWhoa's Avatar
MrWhoa
MrWhoa is offline
Old 03-16-2004, 09:17 AM
andy@ross-tech.com
The Madness unit appears to be a relabelled and price-increased SPI unit.
Old 03-28-2004, 09:59 AM
andy@ross-tech.com
I just installed the $25 gauge and it works great! I'll take some pics and post some numbers later.
Old 03-28-2004, 11:45 AM
andy@ross-tech.com
Seems to respond quickly. I went out for a brief drive and saw 95 C peak (205 F). I'll do some logging with the IAT temp to see how good of a job the intercooler does.
Old 03-28-2004, 01:25 PM
andy@ross-tech.com
I did some 2nd gear runs (highway runs will have to wait til later) and found the intercooler efficiency to be in the range of 60%-80%. Here are a few data points:
abs in abs out ambient initial diff after diff efficiency
358 314.25 292 66 22.25 66%
366 314.25 292 74 22.25 70%
338 300 292 46 8 83%
Old 03-29-2004, 06:38 AM
Hubert's Avatar
Hubert
Hubert is offline
Andy,
Can you please explain how I'm supposed to read these numbers?
Take the 3rd dataset for example:
(338-46)/(338-8) = 88.5% ?
(292-46)/(292-8) = 86.6% ?
How do you arrive at 83%?
Thx.
Old 03-29-2004, 06:53 AM
Hubert's Avatar
Hubert
Hubert is offline
Andy,
I take that you've used the portable gauge to measure the intercooler inlet temp. What about the intercooler exit temp? I have no idea what the TMAP sensor is, and how data can be retreived from that.
It would be great if you could test the large Alta intercooler as well someday :smile:
Hubert
Old 03-29-2004, 07:40 AM
andy@ross-tech.com
Hubert,
Sorry, the formatting didn't work as I wanted.
absolute temp intercooler inlet= 358 K
absolute temp intercooler outlet= 314.25 K
absolute temp ambient= 292 K
inlet - ambient = 66 K
outlet - ambient = 22.25 K
efficiency = 66%
absolute temp intercooler inlet= 366 K
inlet - ambient = 74 K
efficiency = 70%
absolute temp intercooler inlet= 338 K
absolute temp intercooler outlet= 300 K
inlet - ambient = 46 K
outlet - ambient = 8
efficiency = 83%
I logged the TMAP using prototype BiM-COM logging software, but you could get the same data by using a second temp sensor in the intercooler outlet.
Old 03-29-2004, 08:24 AM
caddman's Avatar
caddman
caddman is offline
Hey Andy illo some data collecting on my modded water to air tomorrow and see what we get.....
Old 03-29-2004, 05:43 PM
Hubert's Avatar
Hubert
Hubert is offline
Andy,
Thanks so much for clarifying. This information is really useful for comparing intercooler designs! Now given that this data is fairly accurate, it makes me wonder how the large Alta air-to-air claims to be able to drop the charge temp a further 40 kelvin at max? You'll need the intercooler inlet to be over 398 K (125C) for this drop to be possible for the same ambient temp (19C). And given that the temp drop across the stock intercooler would increase with inlet temp, the inlet temp would need to be in the 420K range
What would be the max intercooler inlet temp we can expect from the stock pulley, 15% or 19%?
Cheers,
Hubert
Old 03-29-2004, 06:10 PM
andy@ross-tech.com
I ordered a second temp gauge for the intercooler outlet, so I can keep an eye on those temps even when I don't have the laptop seatbelted into the passenger seat (not often). :smile:
I haven't done any IC efficiency calculations at fully warmed up highway speeds ... yet.
Old 03-30-2004, 11:17 PM
Hubert's Avatar
Hubert
Hubert is offline
Hi Caddman,
Did you buy the SP temp gauges? If so, where would be a good place to fit them? Any figures to share perhaps?
Cheers,
Hubert
Old 03-31-2004, 09:05 AM
caddman's Avatar
caddman
caddman is offline
Yeap i got the Sp guages, i mounted the sensors in the intercooler just passed the rubber boot that fits to the intake peices, I should have mounted in the intake pieces to be able to change intercoolers to see there effects, but I really like my custom water to air and dont think i will be changing it, i also mounted a water temp guage to monitoer the water in the intercooler, to see how it changes and reacts.. illpost some results when i get the car back together from modding the supercharger, so far i have got as much as 98d (F) temp diffrence from inlet to outlet, but i will make a couple of runs around to give more details....
Old 04-01-2004, 11:02 AM
caddman's Avatar
caddman
caddman is offline
OK ill let Andy do the math for me....
Ambient temp Water Temp Intercooler IN Intercooler OUT DIFF
Idle 68 76 111 79 -31
Hwy (80mph)68 72 149 91 -45
cruising
Hard ACCEL 68 80 191 101 -90
from stoplight
the water temp is up at the stoplight due to sitting waiting on a train...
All temps are in F
Old 04-01-2004, 11:03 AM
caddman's Avatar
caddman
caddman is offline
that sucks i had it all spaced out nicely :evil:
Anyways im sure you can read
Old 04-01-2004, 11:23 AM
andy@ross-tech.com
I just got my second cheapie gauge - YAY! Now I can see both inlet and outlet at the same time.
Here's Caddman's numbers:
inlet - ambient = 111 - 68 = 43 F
outlet - ambient = 79 - 68 = 11 F
efficiency = 75%
cruising
inlet - ambient = 149 - 68 = 81 F
outlet - ambient = 79 - 68 = 23 F
efficiency = 72%
from stoplight
inlet - ambient = 149 - 68 = 123 F
outlet - ambient = 101 - 68 = 33 F
efficiency = 73%
Old 04-01-2004, 12:33 PM
caddman's Avatar
caddman
caddman is offline
um andy, i think you need to check something...on the hard accel....
191-68=81
101-68=33
Quick Reply: Drivetrain How Can I measure IAT?
