Drivetrain Piston/parts suggestions. Doing another rebuild
I have main bearing issues so its time for another rebuild. I am looking for piston suggestions and any additional part suggestions while I have the engine out. I already have most of the goodies, (cam, header, head,) Is there something that is a MUST that I should look into?
Its a daily driver. Ive done one rebuild and put high compression pistons in with methanol and I have never been able to make it run very good consistently. Plus it went through a quart of oil every few thousand miles and has metal shavings in the oil filter. I want the car to also be able to go with out methanol if I need to. I just want a good runner.
Sounds like you need to new engine builder.. and depending on who has messed with your head.. Lots more to a port and polish then just grinding out material... Alot depends on what kind of power your looking for..
Did you get it "tuned" afterwards? A stock R53 w/pulley and your cam and header, and the same guy tuning it you should have had about 215-220 HP ( no meth ) plus more depending on your " homebrew head work" ( assuming this isn't hurting HP ) As with anything it's all a matter of how much money do you want to spend!!
Don't think of meth as a power adder but a power maintainer... As everything gets hot it will help "maintain" the HP you do have..
Does mahle make a .5 over? My block has 12k since last bore, 80k total with the car, should be fine still.
I got these crumby pistons from a vender who recommended them. He probably didnt mean to cause me harm but I am done with tht particular vendor-
XsV
24
09-30-2015 03:17 PM
SneedSpeed
09-10-2015 07:22 AM
