Drivetrain SS Brake lines/fluid for JCW. Suggestions?
I'm looking to switch to stainless steel brake lines on my factory JCW. I use the stock JCW pads and do very aggressive street driving, no track. The search function wasn't all too helpful.
What lines are the safest and most reliable? What brake fluid should I purchase?
I'm going to have a BMW shop do the install while they're doing my suspension. Any odds and ends I should inform the mechanic about?
Thank you for all the help!
Best,
Gene
Best,
Gene
Hello, I am new to the forums but when I was on BMW side you can't beat super blue brake fluid.
http://www.ecstuning.com/Mini-2007-C...g/Fluid/ES111/
Detroit Tuned sells stainless steel brake lines...
http://www.detroittuned.com/detroit-...l-brake-lines/
One thing I will say about the DT ss brake lines is the heat shrink sheathing they put on the outside of the line prevents you from sliding the rubber grommet into the position you need for install without tearing the plastic sheathing itself. I got one to slide over the sheathing by using some breakfree spray but two of them just wouldnt budge without tearing. It was almost like the heat shrink was welded to the grommet. I already had the lines off, etc. so I wasn't in a position to return them. Not sure if this is the norm with these brand lines or if I just a had a bad set but it's not something I was concerned about regardless but it may be an issue for some.
Vendor
Check out our WMW stainless lines they are the same ones used on the Grand Am Bspec MINI's.
As for fluid we do not recommend the ATE fluid. I've seen way too many times that it does something and ruins the feel of the system by being spongy even with fresh fluid in them. Also the dealer will void the warranty if they see the blue fluid in your car.
I do recommend the Motul RBF 600 as it has a higher boiling point and is amber so it looks stock.
I have 96,000 miles on my 09 JCW. Still running the OEM brake lines. Not sure I see the value in changing if you are not tracking the car. Agressive street driving is still on the street.
I think I would spend that money on something else. But if you do decide to change Way is correct, you can have your warranty voided so be careful.
-Gene
ATE isn't eating up seals in the master cylinder is it? I got two bottles of ATE Super Blue for X-mas after thinking I might be overdoing it running Motul RBF600 all last year...
Vendor
As for NM lines verses ours. They are made by different companies is the biggest difference, also I'm not trying to make a fortune off ours. I can tell you we do use exact fit fittings on our lines, theirs are a little different and ours are DOT approved.
FYI... for anyone interested.
I installed the lines, which are great, but I did not receive the result I was looking for. When I installed them on my C6Z06 the already great pedal feel was much more improved and instantaneous. On the mini however there is no difference I can feel. Guess it's just the nature of the two different systems. So if you're going SS for safety, go for it. If you're doing it for feel, don't waste your time.
Best,
Gene
Best,
Gene
07-16-2020 12:54 PM
