Drivetrain Question regarding wideband and OBX header
Hey, I've bough an OBX header and a wideband last autumn and I'm wondering about the clearance down there to install it, I know it need to be installed at a certain distance from the ports and preferably at 12 o'clock. Does anyone have an OBX header with a wideband and can chime in? I still need the bung to be welded on, so that's why I want to make sure that I don't put it somewhere, but end up having to move it after. Thanks!
Thing is, I know where it's better to install it (and yes, I do have the installations, it's brand new :p), I was wondering about the clearance. I'm not planning on paying to get the header installed by someone else, so that's why I want to know if the clearance is ok to install it on top, so I can get the bung welded. I know OBX headers were popular for a while, so I was sure there would be a bunch of people with it and a wideband. If I test fit it, I pretty much lose the car for a couple days, so that's the part that I don't like.
Yeah, well, the OBX header not being a ''bolt-on'' updgrade, I don't know if it will come out in the same spot as the oem manifold. That's why I'm asking someone who have an OBX header installed. If it comes out a bit lower, I'll have plenty of space, otherwise I won't. I'm trying to plan ahead, because I'll most likely install it at the garage where I work, there's no way I'll install this crawled under the car at my house when I can use my lift. That's my main concern, as we don't have a proper welder at work (being a dealer) and me not having the proper skills to use one to start with (thank you stupid teacher). So removing the stock manifold, test fitting the header, then removing it to weld the bung and putting it all back together, as well as modifying the bottom part (because I don't want to run the crappy ball joint gasket that came with the header), all this with the small amount of time I can stay at the shop after my shift, well that would be a bit of a pain. Anyway, if I can't find anything, I'll most likely ask a co-worker that isn't working (not enough work at the shop right now) and do the full exhaust setup while I'm at it.
08-19-2015 12:51 PM
08-12-2015 01:24 PM
Ambient Thermal Management
08-07-2015 12:27 PM
