Drivetrain Putting Car on Jack Stands
There are only 4 lifting points on the car so I don't understand how to put the car on jack stands when you have to use the jack to lift the car. Sorry I am an amateur. I don't think you can jack from the rear because the exhaust goes right through the center. Is there any other jacking points not stated in the manual? Thanks!
I usually put a 2x4 between the jack points under the side skirt and jack from there. It seems to work pretty well. I've also jacked on the frame near the front, which also works well provided you find a good spot.
I'm not sure why you started the thread in this subforum. You'd be more likely to get responses in a more general subforum, not the modifications subforum.
What are you working on, how many wheels do you need in the air at once? I normally jack up one side with the front jack pad, then put a jack stand under the front subframe. I usually then just leave the jack in place, with the stand as a safety. You can get a jack stand on the rear subframe, but I don't feel that good about it. I trust my floor jack, and use one of the aluminum inserts in the jack pads.
http://www.ecstuning.com/Mini-2008-C...Pad/ES2603147/
Have fun,
Mike
Have fun,
Mike
Leaving the jack on the jack point, even with a "safety" jack under the subframe, is less than ideal from a stability standpoint--it's not good for the jack either.
Of interest, Sears used to sell a device that raised the car and placed a jack stand at that same spot. Called 'Lift-N-Secure' or something like that. There must have been liability problems, because it quickly disappeared from their stores and catalogs. But I thought it was the ideal solution to exactly what the OP is describing.
http://www.blimeycabrio.com/?cat=3&paged=2
07-16-2020 12:54 PM
08-07-2015 05:55 AM
