Drivetrain Burger Motorsports (BMS) Tune(s)
Old 11-07-2013, 05:25 PM
ClubmanRob's Avatar
ClubmanRob
ClubmanRob is offline
Originally Posted by MiniMoic
Im at 8000+ Wondering If I should pull the trigger...
Just ordered one. Here in EP TX also. Bone stock Mini Coop S Clubman. Also got a ddm race intake on the way. Gonna see how it goes.
  #902
Old 11-07-2013, 08:14 PM
aleclee's Avatar
aleclee
aleclee is offline
Originally Posted by chrunck
I'm in Albuquerque, which Wikipedia says is 5300 ft. I've been really impressed with the JB+ and saw a big increase in acceleration. I ran it at the stock setting for a few weeks but dialed it back a notch last weekend since we only have 91 here. I wasn't having any problems with the stock setting, but I decided to play it safe.
I live at about 5900' and the effect is very noticeable to me. I'm planning on dialing down a notch as well since 91 is the best I can get here in CO.
  #903
Old 11-08-2013, 02:13 AM
StrikeZ's Avatar
StrikeZ
StrikeZ is offline
I will wait until spring to try this. I am just getting done with the break in period. I am still getting used to the jump in power and performance from an r50 to a r58S. These JB+ looks safe, but I will give it a few months to see if it causes others problems.
  #904
Old 11-09-2013, 05:05 AM
bmx045's Avatar
bmx045
bmx045 is offline
my jb+ and can tool is for sale in the marketplace, take a peak. moving to N54 AWD platform.
  #905
Old 11-09-2013, 09:59 AM
yesti's Avatar
yesti
yesti is offline
Getting a JB4?
  #906
Old 11-09-2013, 10:04 AM
bmx045's Avatar
bmx045
bmx045 is offline
Brentune with AP v3
Sent from my banana phone
  #907
Old 11-09-2013, 04:20 PM
Tigger2011's Avatar
Tigger2011
Tigger2011 is offline
Alliance Member
Finally got around to installing the JB+ and new plugs after the DP...Holy crap what a difference. Terry and gang, you guys are my hero's. This is how the car should have been from the factory. Once break in, data logging and tweaking is done I'll post before and after dyno runs.
Urkel has been transformed into David the giant killer lol.
Now if Terry would only let me pay him for a JB4....
  #908
Old 11-09-2013, 04:46 PM
MINI4LYF's Avatar
MINI4LYF
MINI4LYF is offline
The real question is...where can I get a banana phone??
  #909
Old 11-09-2013, 05:57 PM
yesti's Avatar
yesti
yesti is offline
Maybe he's just happy to see you
  #910
Old 11-09-2013, 10:28 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
I'm at 100% with my JB+ 30% E85, 20psi and tons of timing. Using my new front Spiltter to keep the front wheels on the ground loving my GP2
  #911
Old 11-10-2013, 08:42 AM
MiniMoic's Avatar
MiniMoic
MiniMoic is offline
New Plugs?Why?
Did you dialed it with the new plugs?
  #912
Old 11-10-2013, 08:53 AM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
And I'm hesitating on bumping up to 6 with 93 and all my mods... 100% must be nuts!!
  #913
Old 11-10-2013, 10:22 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
My thoughts exactly.
  #914
Old 11-10-2013, 11:08 AM
ThumperMCS's Avatar
ThumperMCS
ThumperMCS is offline
Be careful....lol
Get it on a dyno! I'm curious to see what its putting out
  #915
Old 11-10-2013, 02:19 PM
MarioKart's Avatar
MarioKart
Vendor
Originally Posted by ThumperMCS
Be careful....lol
I'm curious to, need DP first
  #916
Old 11-10-2013, 06:41 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
New Plugs?Why?
Plugs had 50K on them so I installed Denso IXUH22 plugs and closed the gap to .027. I like the u channel groove and the .04 iridium tip as opposed to the NGK .06 tip. Requires less voltage to initiate the spark and the grooved electrode should help protect the spark kernel from blow out under high boost. I already had the 16mm socket from my first gen mini but had to buy the 14mm 12 point just to remove the NGK's lol.
Right now I'm running at the 2 o'clock position with no pulled timing. Going to give it a little while more to adapt then edge it up again.
"You never know what is enough unless you know what is more than enough" - William Blake
  #917
Old 11-10-2013, 08:19 PM
wzabrouski's Avatar
wzabrouski
Plugs had 50K on them so I installed Denso IXUH22 plugs and closed the gap to .027. I like the u channel groove and the .04 iridium tip as opposed to the NGK .06 tip. Requires less voltage to initiate the spark and the grooved electrode should help protect the spark kernel from blow out under high boost. I already had the 16mm socket from my first gen mini but had to buy the 14mm 12 point just to remove the NGK's lol. Right now I'm running at the 2 o'clock position with no pulled timing. Going to give it a little while more to adapt then edge it up again. "You never know what is enough unless you know what is more than enough" - William Blake
Running any E85?
  #918
Old 11-11-2013, 05:42 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Haven't needed to yet. There's a Shell about 4 blocks away that sells it. So it's handy when I get to that point.
  #919
Old 11-12-2013, 06:25 AM
MiniMoic's Avatar
MiniMoic
MiniMoic is offline
About to pull the trigger on this. I still wondering how to monitor boost (i mean, i can do that with the CT or Torque, but then what?), and what do in order to compensate for 8000ft, if any...
  #920
Old 11-12-2013, 08:54 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
No need to compensate. Most monitoring apps DC, Torque etc take into consideration barometric pressure and report calculated boost pressure.
  #921
Old 11-12-2013, 09:00 AM
iminir56's Avatar
iminir56
iminir56 is offline
How do you know when timing has been pulled? And what do you look for when monitoring afr?
Sorry for the noob questions...
  #922
Old 11-12-2013, 09:02 AM
MiniMoic's Avatar
MiniMoic
MiniMoic is offline
I was talking about what to do with the JB controls. Lets say, ok boost is (any number) or timing or fueling, and then what to do with the JB+...
That was what I was wondering,
  #923
Old 11-12-2013, 09:28 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Probably got some more knowledgeable people here that can answer better than I but here goes. AFR is normally going to run 14 and change but lean out at high rpm and boost down to around 11.7-12.0 or so. If I saw consistent numbers <11.5 I'd be concerned. Timing will under varying load condition and run from about zero to +6 degrees under boost dropping off sharply when shifting. If you see a sudden reduction of 4 or more degrees when you shouldn't then it pulled timing.
  #924
Old 11-12-2013, 09:41 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Actually with AFR it should be 14.7 (stoichiometric) and for forced induction motors like turbos, the ratio will slightly drop (run richer to prevent knock) to about 12 under load and boost. This drop is a good thing.
When I've monitored AFR I've consistently experienced this.
  #925
Old 11-12-2013, 10:48 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
Oops yep what he said on AFR's. Got my AFR confused with my O2 voltage readings mixed where lower is leaner. Thats what i get for working on one thing while answering another. Thanks for the correction.
Quick Reply: Drivetrain Burger Motorsports (BMS) Tune(s)
