Drivetrain Burger Motorsports (BMS) Tune(s)
#76
i mentioned to terry on wed that i was prob going to pick up the evolve dp. he said something to the effect of "that should free up the engine a bit." i got my invoice from alex and am about pull the trigger. it may be a little while before i get it on the car. i would love to be able to quantify the gains i get over stock - stock vs. dp, stock vs. JB+, stock vs. dp + JB+.
#77
I will keep my eyes posted if you or someone else is going to post dyno gains on the examples you stated.
#78
#79
on
Update: on the way home from dinner it did the same thing as before where the dash hack never unlocked. So when i got home i unplugged the can tool. uploaded everything back through. checked all my settings and i did 2 pulls and all works according to plan. I didn't do any off throttle back on throttle to see if it would mess up again but i did 2 1st-2nd gear pulls and it worked fine and flipped out of dash hack like it was supposed to. i'll keep ya'll updated. i'll play with it on the way to work tomorrow.
#80
When you say passive what do you mean by that exactly, does that mean the condition is harmless to the car/engine? In this case it's just an emission type thing?
#82
#83
They definitely are, the JB4 will be available for us in the future.
And I'm hitting 18psi because I have meth, which keeps things cool, so the increased heat generated is no biggie.
I was given the green light by Terry because I have the meth, so he was comfortable letting me increase it a bit. There is a dial inside the JB+ that's lets you adjust between min-max.
I do also have all the relevant bolt on stuff to give some more power gains.
#85
"Not locked to a specific VIN -- use on as many cars as you'd like"
#87
do realize that the CAN tool must be connected to the OBD II port. so while you can switch between cars, you obviously can't have it running on both cars at the same time. just wanted to clear that up for you.
#88
Yeah I know, I was under the impression that I could sort of "flash" the specific features I wanted. Wasn't sure if it needed to be connected at all times. If that's the case I guess it makes sense. I keep AP plugged into the obd port most of the time so if I need to leave it plugged in I don't think I can use it on the mini
#89
#90
So regarding the shift light feature on the CAN tool, I have an auto so I was wondering what RPM to set it to as sort of an "eco" shift point where I would let off the gas and let the tranny upshift for me to get the best mpg? Or if that would even make a difference at all (waste of time and blinking lights). Looking at various stock HP/tq graphs it seems like a reasonable point would be around 2600 rpms since that us where the torque bump goes back to ~170 lb/ft before dipping below that until ~4250 rpm. I'm using the baseline vs. NM engineering graphs btw. Although I probably should be looking at JB+ graphs, right? Just thinking out loud here, any input is appreciated.
#91
#93
#95
#98
