Drivetrain Burger Motorsports (BMS) Tune(s)
#1601
Your JCW tuning kit will only at probably 5whp if any. I know for a fact they said it adds 8hp. But I would check with those guys, your numbers just seem a little low.
#1602
Your only know variable for your baseline is rpm and air temp? A better understanding of how a car compiles many other variables per sec to attain timing is the only way to achieve a "known" baseline. Simply advising someone to monitor timing based on rpm and air temp is pointless and somewhat reckless as it could lead to a false positive.
throttle position (WOT), load (to some degree), rpm, air temp, fuel.
I don't believe that anyone advised anyone to monitor timing based solely on rpm and air temp. That was never said nor implied. I'm telling you how I do it and it's based on a lot more than that. But it's important to note that you might not experience knock in the winter but might in the summer, so if you turned up the dial be careful in the hotter weather (especially since boost will also go up).
I believe that it was recommended to keep they dial at 50% and NOT to touch it. Then it was discussed here that if you do turn up the dial to make sure that you have sufficient octane to support it. One way to determine if you have sufficient octane (with the tools and sensors that we have) is to monitor timing during WOT and high RPM (the JB+ has little/no effect during normal leisurely driving). If you don't see timing being retarded then you should be ok.
That being said, tuning a car is a risk just by itself. Then turning the dial up against the tuners recommendations is even more of a risk. People have been warned and are doing this on their own accord. Hopefully they aren't using this thread as their only source of information when your taking about a +$5000 engine repair if things go bad.
#1604
#1605
The comment "if you don't see timing being retarded you should be ok". Really? What is advance or retarded? Both you and I hand no idea, we do not have the factory timing tables and you have no way of monitoring load which is one of the biggest variable of the baseline timing. You can not accurately monitor timing without knowing what the factory timing is and the resulting other affects of engine load, throttle position, knock, air temp, and boost. All of these are scaled, so without a datalog you are fishing without a worm.
#1606
We are trying to see if we can turn up the dial on the JB+ which I believe basically calls for higher boost (this is simplified), a side effect of higher boost is knock, so are we experiencing knock? One way to determine if the engine is knocking is to see if timing is being pulled. If I monitor timing and it's steady or advancing then it's not being actively pulled so I'm probably not knocking, I'm probably ok. If I see that timing is being actively retarded then I'm probably not ok. The method is not perfect but it's better than nothing.
I agree with you to a point, but I'm doing the best with the tools that I have with a device that just plugs in.
#1607
No imperial data....you have zero idea what you think you see and have know way to prove it to anyone other than convincing yourself by saying "you think you have no knock". Trying no to be tough on you but you have a lot of learning to do before you understand what you are talking about. As a group, we all need a way to datalog these cars to monitor under differing conditions.
#1610
I'm just disagreeing with your initial comment of "...monitoring timing is a waste of time...all these are wild guesses and nothing more." I believe it to have some value if used correctly.
I do use DashCommand to log and graph different parameters (RPM, timing, temp, AFR, boost, load (not sure if the JB+ makes this calculation erroneous). It might not be ideal but it is something.
When it's all said and done doing all this stuff is lots of fun.
#1612
Anyone want to kindly send me a "graph setting" for ScanXL? My email is eddiepagal@gmail.com
Thanks in advance!
Thanks in advance!
Here's a link to my google drive where you can download my graph layout:
https://drive.google.com/file/d/0B9g...it?usp=sharing
#1613
Man my cooper s only gets 200whp :( but I'm also getting 230 ft - lbs what mods are u running?
#1614
Mine looks like this:
#1615
on
Attachment 87443 211 hp 230 ft lbs Today's dyno !!! Coming from a cooper s I think it's a pretty good result Is it safe for the engine to be pushed even more by adding to my to my modes a jb+ ? I heard that the n18 engined are no that strong to cope with a lot of hp .
#1616
on
No one knows the timing tables for each gear and load target..until this is know "monitoring" timing is a waste of time. There are millions of combined variables between in each gear between air temp, throttle position, load, fuel,false knock from something loose in the engine bay...ect ect..until Terry or another vendor can offer a way to data log these variables, these are all wild guesses and nothing more.
On timing its a very dynamic measure. The CT is also only showing cylinder 1 timing which can and will vary from cylinder 2, 3, or 4. But the reason we keep an eye on it is not to compare it to some absolute value as such a value can't be predicted by an end user. But to look for signs of over aggressiveness which would be reflected by repeated 3 degree timing dips at higher RPM.
#1619
#1622
A lot a factors come into play. The weather, elevations, cooing, fuel, back pressure. All this can be monitored for under $200. My car makes goobs of HP and TQ (for a mini) and it's "vitals" are better than stock.
Sent from my iPhone Office
#1624
What engine do you have? With 92 octane the recommended setting is 12'oclock for S and 11'oclock for JCW/GP2. Are you monitoring timing under full load WOT?
#1625
I don't see a problem running 18psi. You also need to look at your timing and afr. I'm running 18-19psi at 70%. Timing is fine during cold temps but have issues when it warms up. I have to turn down the dial to 60% on warmer days. I'm also mixing 30/70 e85/91.
