Drivetrain Burger Motorsports (BMS) Tune(s)
#1826
#1827
Regardless of what setting I choose to run the JB+ I still think that BMS should respond to my question as to what I should be monitoring and what parameters to look for...not too much to ask. Simple question...I though I could ask here since there are a lot of guys running this product.
Thanks for the help.
#1828
http://burgertuning.com/contact.html
#1829
Regardless of what setting I choose to run the JB+ I still think that BMS should respond to my question as to what I should be monitoring and what parameters to look for...not too much to ask. Simple question...I though I could ask here since there are a lot of guys running this product. Thanks for the help.
Are you even using E85?
#1830
I think that Terry or someone with BMS should type up better instructions on how to use the different CAN tool options because like I just said, what they have on their site doesn't go in to much detail and their YouTube video(s) aren't much better.
#1831
Reading through almost 100 pages isn't an easy task. Trust me, I've been read through them all which has taken me almost one week. I just got my JB+ a few days ago and I have several Q's that aren't in the instructions on Terry's site which are very very general directions at best.
I don't understand why someone wouldn't find the time to read the forum that contains just about every bit of info one would need to educate themselves on what they are doing to their motor, but is OK with blindly installing something and modifying it otherwise.
But hey, let us know how that works out for you.
#1832
also: (from the burger site)
There is a blue adjustment dial inside the JB+ that lets you fine tune its overall aggressiveness. The dial runs
from 0% (MIN) to 100% (MAX). Adjustment is made using a small standard screwdriver. The adjustment dial
is sensitive so be careful not to use too much force when adjusting
The JB+ comes preset at 50% and generally should not be changed for normal N18 motors using good quality
pump gas. Those running higher boost tuning from the factory such as the JCW package, or those using
exceptionally poor fuels, such as 90 octane or lower, should reduce the dial to 30-40%. Conversely if
monitoring boost & timing using a BMS CAN Tool or similar the dial may be adjusted up on higher grade fuels
such as race gas, E85 mixtures, or methanol.
#1834
The JB+ wasn't designed to just be turned up at random. The site states it's designed for 93 octane at the default setting, to which you aren't considering.
I thought this was a site where we could all post and ask questions to help each other out...My question was what parameters should I be looking for when monitoring the jb+ no one here nor the guys at BMS have answered that question but thanks for telling me how I'm not educating myself. I will read all the pages now...thought I could save a couple of days by just asking.
PS I have an Engineering degree form UCI, I'm a medical laser Engineer, I have my own shop where I custom design parts and fabricate them, I also build race cars and built the first challenge race car for Crevier Mini here in CA.
But since I don't know what I'm doing I'll just keep turning this thing up and I'll add nitro methane to the mix cus it will make my car faster.
#1835
Don't mind everyone that's taking a stab at you. There are lots of people looking for more power but you'll have to email Terry to give you better instructions. So you know I was at the 2 position and running 70% 93 and 30% e85. But I dialed it down to 1 and using only 93. Everything checks out fine. Be careful with the warm weather!
#1837
#1838
Thank You MRDustyPants...
Since you know what you are doing, have fun cranking up the JB+ on 91 octane.
#1840
on
Arrg...
No point in being worried, you can't do anything about it now.
I've never experienced a boost cut, but recently I one of my intercooler charge pipes came off and the car just fell flat.
I believe when the ECU cuts boost it just opens the wastegate. I wonder if it could have been pulled timing.
I'm getting frustrated. So, since the Boost cut or sudden slump, like hitting the breaks and then accelerating out problem occurred, I have put it back to the 12 o'clock position. How ever, its still happening when I hit boost. Not sure what PSI, but it has to be 5-10ish cause the fuel gauge gets hijacked when it occurs. any thoughts... No CEL, no signs of Limp Mode. This is confusing. Is there a time period I must allow for the DME to recognized that the dial has been turned down? Or is it because I'm running it at 50% with a 95-96 octane blend?
#1841
#1842
#1843
#1845
The JB+ alters the signals that are being sent to the DME (ECU), effectively making the DME call for higher boost.
A DME tune actually changes the factory maps for various parameters such as boost, timing, AFR and others. This can be done by flashing the DME through the OBDII port or pulling the DME cracking it open and doing it on a bench. Currently for the N18, flashing via the OBDII port is not possible but the buzz is that it will be shortly.
#1846
Drive the car without it for a bit.
#1847
https://www.northamericanmotoring.co...ct-thread.html
#1850
