Drivetrain Burger Motorsports (BMS) Tune(s)
Old 04-04-2014, 03:36 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Originally Posted by ChaiLatte
Alright. I'm going to ask a question and would appreciate it if you guys didn't shoot me because I did search quite a bit (and didn't understand a whole lot of what I read). But what is the general consensus on turning up the JB+ when you have an Aquamist Meth Kit? I know you can do it, but by how much?
Great question. I'm wondering myself how to figure that out.
  #1977
Old 04-04-2014, 05:02 PM
thekaus's Avatar
thekaus
thekaus is offline
Is an upgraded inter cooler worth the money for average spirited driving? I haven't noticed any outrageous intake or coolant temps so far.
  #1978
Old 04-04-2014, 05:17 PM
Mcameron's Avatar
Mcameron
Mcameron is offline
ide imagine i would probably ramp it up slowly.......start by turning it up 1 notch and run it for a bit and constantly monitor timing....if everything looks good, turn it up another notch and repeat...until you get to a point where you are starting to pull timing, then back it off a notch for buffer room.
  #1979
Old 04-04-2014, 05:24 PM
pidge1114's Avatar
pidge1114
pidge1114 is offline
Originally Posted by thekaus
Swapped the white Union Jack stripe for a custom black jack stripe
That seems really relevant in this thread....
  #1980
Old 04-04-2014, 05:29 PM
MiniFury13's Avatar
MiniFury13
MiniFury13 is offline
I'd have to agree...
  #1981
Old 04-04-2014, 06:33 PM
yesti's Avatar
yesti
yesti is offline
Plus there are all the variables with the meth kit itself. What mixture are you going to run? When should it trigger, what size are your injectors?
Straight meth will richen your A/F ratio, straight water will probably not affect it? (others chime in here)
You probably want a 50/50 bias between IDC and boost pressure trigger. We know if you go 100% boost you run rich and timing doesnt advance as expected.
Others on here with meth kits please share your settings and test results :-)
Edit: some people have gone to 100% with straight meth
  #1982
Old 04-04-2014, 06:45 PM
miniforozzie's Avatar
miniforozzie
miniforozzie is offline
I just installed an Aquamist HSF-4 kit on my '13 MCS and my boost went up from 14 to 16-19lbs without touching my JB+. Any idea(s) why?
  #1983
Old 04-04-2014, 07:09 PM
thekaus's Avatar
thekaus
thekaus is offline
Sorry, my ipad thread hopped on me. My question for this thread was about the need for an aftermarket inter cooler for spirited everyday driving.
I've been running the JB+ for a few weeks at stock setting and haven't felt anything odd or noticed extreme intake or coolant temps even with boost hitting 18 on occasion.
  #1984
Old 04-04-2014, 10:00 PM
NewCooperFanatic's Avatar
NewCooperFanatic
NewCooperFanatic is offline
Don't run 100% water in a R5x S. That's asking for a very strong ignition.
If for what ever reason you WANT to, don't go bigger then a .5mm jet.
A good balance for these cars is 80/20 water meth....if you're lazy like me and don't want to measure, just run 100 meth.
These car absolutely love it.
  #1985
Old 04-05-2014, 01:52 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Do you know your flow rate when in SYS mode? What is your THRES set at? I've only adjusted THRES to 11 o'clock.
I'm using a 0.6mm jet with 0.7mm restrictor and get ~275 cc/min. I'm running ~80% meth (I was too lazy to empty the water out the the tank). I too will be going 100% because it's easy. I might occasionally blend a little water in.
  #1986
Old 04-05-2014, 01:58 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
Are you sure it wasn't temperature related? I too just installed mine and my boost went up but coincidentally so did the ambient temperature (Spring finally arrived here in North Carolina). I attribute my increase in temperature because in agrees with what I was seeing last summer under similar conditions.
  #1987
Old 04-05-2014, 02:08 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
It depends on how far you want to take it in the future. If you're satisfied with what you have right now, I'd say you're fine. Personally, I'm laying the ground work for the potential tunes that might become available here in the near future.
Curious, what are your intake and ambient temperatures when WOT. I never data logged with the stock intercooler.
  #1988
Old 04-06-2014, 08:35 AM
wzabrouski's Avatar
wzabrouski
wzabrouski is offline
Just pulled the trigger on a HFS-4. How did everyone running one come up with th appropriate settings to work with the JB?
  #1989
Old 04-06-2014, 02:52 PM
NewCooperFanatic
Flow rate is going to around ~375cc/min.
Thres is at 11
Gain is at 12....decided to leave it linear.
Flowing enough as it is , no point in ramping up injection.
I also backed down the JB to 12.
I really need to get dash command and that little wifi thing for my iPhone to see what's going on at 100%.
  #1990
Old 04-06-2014, 03:50 PM
SoCalledFriend's Avatar
SoCalledFriend
SoCalledFriend is offline
Just clicked "place order" for my JB+....can't wait to drop this baby in!
  #1991
Old 04-06-2014, 04:24 PM
larmini's Avatar
larmini
larmini is offline
Is it really that noticeable a difference. The jb+ from stock.
  #1992
Old 04-06-2014, 04:49 PM
yesti's Avatar
yesti
yesti is offline
The JB+ or meth kit?
For the JB+ the answer is yes. 20hp/30tq is very noticeable in everyday driving. If you have 92+ octane gas then leave it at default setting and be happy.
Sport = beast mode due to the throttle remapping. Non-sport feels almost like sport mode without the JB+. Getting the hint, yet?
The only problem is it will leave you wanting more which means upping your octane with E85/meth/torco...
  #1993
Old 04-06-2014, 06:48 PM
wzabrouski's Avatar
wzabrouski
Flow rate is going to around ~375cc/min. Thres is at 11 Gain is at 12....decided to leave it linear. Flowing enough as it is , no point in ramping up injection. I also backed down the JB to 12. I really need to get dash command and that little wifi thing for my iPhone to see what's going on at 100%.
When did you put in you meth kit? I just ordered one today.
  #1994
Old 04-06-2014, 07:17 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Hey everyone, I started a separate thread about the Aquamist methanol systems here:
https://www.northamericanmotoring.co...ml#post3909362
  #1995
Old 04-06-2014, 07:19 PM
JPR18's Avatar
JPR18
JPR18 is offline
I tried searching through this enormous thread...but no luck.
My 2012 Cooper S (stock) has had the jb+ for about 2 months...and I've had some little issues.
1) randomly the half-engine light came on and the car went into limp mode. Unplugged it, ran the car stock, and plugged it back in. The car felt faster than it did right before the CEL, like it did after the adaptation period.
2) a few weeks after plugging it back in, and not touching it, the car basically reverted back to stock. It was very strange. Today I was racing so I had to remove the jb....I ran all day without it, and after plugging it back in, the difference was extraordinary. After a few miles on the highway the car accelerated significantly faster, much faster than earlier this week when it was plugged in.
So my question is, is it possible for the car to revert back to stock-like performance? Should I just keep unplugging it and plugging it back in every now and then?
  #1996
Old 04-06-2014, 07:31 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
Originally Posted by JPR18
I tried searching through this enormous thread...but no luck. My 2012 Cooper S (stock) has had the jb+ for about 2 months...and I've had some little issues. 1) randomly the half-engine light came on and the car went into limp mode. Unplugged it, ran the car stock, and plugged it back in. The car felt faster than it did right before the CEL, like it did after the adaptation period. 2) a few weeks after plugging it back in, and not touching it, the car basically reverted back to stock. It was very strange. Today I was racing so I had to remove the jb....I ran all day without it, and after plugging it back in, the difference was extraordinary. After a few miles on the highway the car accelerated significantly faster, much faster than earlier this week when it was plugged in. So my question is, is it possible for the car to revert back to stock-like performance? Should I just keep unplugging it and plugging it back in every now and then?
My friends Mini would have the 1/2 engine light when, he had the JB+ too turned up for the fuel he was using. Make sure you stay under 50% on the JB and use at minimum 91octane. Try tuning the JB to 30% and go to another fuel station to get 91 or higher. If you don't have any issues, turn the JB up slowly. Sent from my iPhone Office
  #1997
Old 04-06-2014, 07:36 PM
wzabrouski's Avatar
wzabrouski
Originally Posted by cerenkov
hey everyone, i started a separate thread about the aquamist methanol systems here: https://www.northamericanmotoring.co...ml#post3909362
+1
  #1998
Old 04-06-2014, 07:46 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
Did you read the codes?
  #1999
Old 04-06-2014, 07:51 PM
JPR18's Avatar
JPR18
JPR18 is offline
I haven't touched the settings since I installed it (so at 50%?) and I always run 93 octane.
I don't have a code reader. I suppose I should get one.
  #2000
Old 04-06-2014, 08:25 PM
NewCooperFanatic
I've had it on for a very long time, and it's staying on for the life of the car.
It should seriously be the very first mod anyone should do before even touching drivetrain stuff. Even before an intercooler....you'll get much better results with methanol.
Many people have no idea how bad these cars need it and the awesome protection it offers.
....but ultimately it comes down to how far you are planning to take the "DD"
Quick Reply: Drivetrain Burger Motorsports (BMS) Tune(s)
