Drivetrain What is "Boost"?
#26
#27
Found this on stumbleupon.com at work a couple months ago. It actually talks about the "twin-scroll" turbo that is found in the Mini.
http://www.stumbleupon.com/su/1JJFCW...uction_3.html/
#30
Maximum boost will be 11-13psia (psi above ambient, ambient = 14.7psi at sea level) unless you get a tune, because the only way to change this is to change the ECU control of the wastegate.
Getting rid of the muffler on the turbo discharge pipe and a larger FMIC will theoretically allow a bit better flow and deliver more air to the engine for increased HP, Alta has dyno charts that show this. But without a tune the gains are small. The other thing a larger FMIC will do for you is keep the intake air temperatures lower under boost, so you get denser air and therefore more HP. My datalogs show that the only place this matters is on the track, on the street you just can't drive that hard for long enough to get the IATs up. Unless you live in Phoenix or Death Valley and have ambient temps above 100F.
#31
#32
#33
Does any one know what the real purpose of that "muffler" is? I just have a hard time believing that the engineers would install a part that muffles the sound at the expense of performance/efficiency (albeit small) and then turn around and install a noisemaker somewhere else.
#35
#37
Okay to make boost simple- When your car idles, it'll read around -20 psi vacuum. Now when you begin to drive normal/crusing. Your car will pull 0psi or 14.7psia- which is what ambient pressure is. When you get on the gas harder(doesn't need to be WOT right of the bat, progressive throttling)and you begin to get the turbo to spool faster an faster until the turbine begins to force air into your intake manifold faster than the motor can let in, you begin to pressurize the intake manifold. This is what we call boost. Literally, you'll feel a spike of power!
Now I'll try to explain why any aircharge/cai/piping isn't a boost adder without a tune. Your engine ECU will control boost using a wastegate. The more air you try to bring onto the "cold" side of the turbo, the higher your wastegate duty cycle will be, so all that precious air you tried to put into your motor is just getting exhausted.
Get a tune with those mods, turn up your boost parameters via ECU. Then you'll get your moneys wortH!
#38
Okay that does make sense, so replacing oem tubes with aftermarket tubes such as NM or ALTA doesnt necessarily add boost but it can handle higher boost situations (please correct me if im wrong). So i guess one of the most performance adding mods you can get is an ecu tune which will also take advantage of any other mods you add (cai, discharge and charge tubes etc etc). Okay, thank you everyone
#39
Think of it this way - it's like blowing through a straw. Your turbo can blow through a thin, constricted straw (discharge pipe muffler and stock FMIC) or it can blow through a fat, wide open straw. Boost pressure gets measured at the intake manifold, the ECU will manage maximum boost the same, but there will be some performance gain without a tune as you'll be able to build boost faster as the turbo is blowing through a fat straw instead of a thin one. Also a larger FMIC will keep the boosted air temps lower, therefore denser so more air to mix with fuel.
#40
Putting that on a MINI wouldn't get you any boost. And do you know what that is used for? My first guess is aviation but it could be for a large ship engine
http://www.boatdesign.net/forums/die...l-34881-2.html
EDIT: Post 21 , and take a look at the wiki article on post 1
Because f*** logic, thats why
#41
Low drag intakes and exhausts allow for efficient spooling which is good no matter what.
On cars that control boost levels mechanically, increasing charge density increases power (to a point - if you knock they generally pull timing advance). In these minis, the ecu seems to manage air input via varying the boost. I plan to investigate this more (only had my mini for 6 weeks) as boost levels are not consistently applied in my 2010. I get anywhere from 12.1-14, all at WOT and across all gears and seems to be external condition dependent. More logging is needed for me to understand what is happening.
#43
you can boost the psi with a tune....
But as many folks found out with overly aggressive custom tunes or "stage 3 canned tunes" the pistons...or more appropriately the skirts around the rings fail at high boost levels....
Engineers speed months calculating exactly how strong to make parts so they can be made as cheaply and lightly as possible.... General rule is you can go a bit over stock....but much more....you start to need custom pistons.....
#44
BOOM!!
Sucks but true.
#45
Kinda right, which my response will be also - entire textbooks are written on this topic. Fatter straw = more volume to pressurize = more mols of air = more turbo lag. Smoother passages, less bends though will decrease drag and increase efficiency. Larger flow area will decrease velocity which will help with efficiency.
