Drivetrain 15% pulley. some questions.
I have just ordered:
1.15% pulley
2. NGK cooler running plugs
3. shorter belt
4. MSD coil pack
5. MSD wires
I am also making an intake. I plan to just buy a cone filter, some metal to bend as a heat shield, and i'm not sure what to use as the intake piping. ideally i would bend a 2.5-3 inch metal pipe.
my biggest questions are regarding the DT belt tensioner stop.
1. why is it better than the stock unit(besides wearing easily)
2. why is it 100$ cheaper than the stock unit.
3. do i need it with the pulley?
(side note. my current belt is very worn on only one side (like the inside is worn and the outside isn't that i have seen) any known reasons why???.. the faulty stock tensioner???
and a few questions regarding the cowl mod. i can see how it would improve air flow and even keep the incoming air cooler. but has anyone heard of water coming through because of this? I have sucked up water from other intakes lucky for me it wasn't this baby
Thank you for your help! any advice is much appreciated!
1.15% pulley
3. shorter belt
4. MSD coil pack
5. MSD wires
Alpha Motoring
09-07-2020 07:34 PM
Emnotek
09-29-2015 07:37 AM
daviday
09-25-2015 01:31 AM
