Drivetrain Door Brake/Check Strap
I've been meaning to fix my drivers side door for a while now. For those who have done this, is buying a new part always in order or is it just a matter of fixing/adjusting what is already there? Ideally I would like to attempt to salvage what I have rather than buying a new one. From what I've read its a very straightforward job, but is there any tips or tricks I should know before I start?
There are two types of door brakes dependent on your year. Ones for up to 5/2003 and ones from 5/2003 on , for the Gen 1 MINIs. R50 R52 R53
Door Brake - Priced Each One per door -5/2003 production part # 51211166471
http://www.ecstuning.com/Search/SiteSearch/51211166471/
Door Brake - Priced Each One per door 5/2003 and up production Part # 51217176811
http://www.ecstuning.com/Search/SiteSearch/51217176811/
You can spray them and add some grease but it they still pop and click you have the parts linked here. I would also spray #2 and #3 hinge as they will help pivot the door better.
Also inspect the door brake and make sure the little bolt on the door and to the body are tight.
Great, glad I could help.
Dependent on what type you have above, they come pre-greased in certain locations. See the pics, black type is pre-gressed on the upper and lower spring mechanisms and pivot, metal finish and greased on the roller end and spring. You could use a little light brown grease similar to the sunroof grease. Or white lithium grease.
Navigation & Audio HK Replacement With New Components
Filmy
15
06-06-2023 07:27 AM
