Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
Old 06-12-2014, 05:18 PM
pidge1114's Avatar
pidge1114
pidge1114 is offline
  #427
Old 06-12-2014, 05:43 PM
CPap's Avatar
CPap
CPap is offline
Originally Posted by pidge1114
Jealous! Make sure you post your progress! You think RSW will ship to me? It doesnt show on their online store, but I'm sure its too new.
I will report back for sure. They just got them in a day or so ago. They should ship.
Originally Posted by jkapinos
If in stock. I have not received mine yet. It was to be mailed after they received them.
Give them a call.
  #428
Old 06-12-2014, 05:47 PM
jgray205's Avatar
jgray205
jgray205 is offline
They'll ship it...I emailed them and they sent UPS...received mine today but not sure how to use it as it didn't come with any instructions. I emailed Nick at Manic and am waiting to hear back.
Sent from my SCH-I605 using NAMotoring
  #429
Old 06-12-2014, 05:55 PM
johntotah94's Avatar
johntotah94
johntotah94 is offline
Originally Posted by RobMuntean
http://www.minitorque.com/forum/f13/...26/index3.html
did some research to see what kind of dyno's would be found in Europe(gas is better there obviously). Check out one of the guys dyno's on this page. Click on his link, very impressive for a custom tune and similar mods to my MINI, besides the Forge DV.
So John, you might see close to those numbers for sure!
Id love to have that much power! I noticed he has an upgraded turbo which helps. I'm pretty sure if he ran the Evo Plugs he can get even more power out of it. I ran the M3 plugs and they were ok. The gap was too big and didn't like when nick added more boost. Evo plugs have a tighter gap that runs great with more boost. I might get a JCW Turbo when the funds are right. He got 258whp and 258wtq on it!!
  #430
Old 06-12-2014, 07:15 PM
RobMuntean's Avatar
RobMuntean
RobMuntean is offline
That's exactly my plan is to get a JCW turbo sometime next year if funds permit. But I've looked into other plugs, where can I get EVO plugs from specifically?
  #431
Old 06-12-2014, 07:17 PM
johntotah94
I forgot the NGK part number but it is in my signature. You have to order it online from NGK or EBay. That's the only place I found them.
  #432
Old 06-12-2014, 07:18 PM
CPap's Avatar
CPap
CPap is offline
[QUOTE="johntotah94;3946835"] Id love to have that much power! I noticed he has an upgraded turbo which helps. /QUOTE] He's running a massive turbo(relative terms) k04 63.5! If I read what he wrote correctly! Thing must come on at 4k.
  #433
Old 06-12-2014, 09:28 PM
RobMuntean's Avatar
RobMuntean
Thanks John!
  #434
Old 06-13-2014, 01:30 AM
jkapinos's Avatar
jkapinos
jkapinos is offline
I got the plugs thru amazon.
  #435
Old 06-13-2014, 05:57 AM
CPap's Avatar
CPap
CPap is offline
Check out the functionality and the how to video in this link.
http://www.revotechnik.com/sps/
I contacted Nick about the communication, anti-theft and firmware update settings on the SPS. Not sure if those are accessible to us or not. The anti-theft setting is what really intrigues me.
  #436
Old 06-13-2014, 06:22 AM
pidge1114's Avatar
pidge1114
  #437
Old 06-13-2014, 06:38 AM
CPap's Avatar
CPap
CPap is offline
Thats a great walkthrough! Curious that they are considering Map C to only be used with Race Fuel...Nick didn't say anything about that.
I think it depends on your application.. turbo set-up. The more air your push, the more fuel you need. With my set-up, I need to run race fuel or meth on Map C. On the stock turbo, it may not be an issue. I would ping Nick on it to make sure.
  #438
Old 06-13-2014, 07:03 AM
jgray205's Avatar
jgray205
jgray205 is offline
Thanks a lot! Nice tutorial...
  #439
Old 06-13-2014, 08:56 AM
Go-Cart's Avatar
Go-Cart
Go-Cart is offline
I am curious about this same thing. I have a 2013 JCW and want to be able to take advantage of higher octane fuel. I know the stage 2 setup is tuned for 91oct and was not sure if running 100 oct fuel on that tune would even help much. Was kinda wondering if I would be able to safely run the stage 3 tune on the stock JCW turbo? Wasnt shure if I would have to have a bigger turbo to get the benefits of the stage 3 tune? Any thoughts? I already have intake, fmic, downpipe.
  #440
Old 06-13-2014, 09:15 AM
CPap's Avatar
CPap
CPap is offline
The staged tunes are set up for your particular mods. The maps loaded in the ECU are set for different octane levels and/or meth spray. When you get a tune, whether it be stage 1, 2, 3... you get 4 different maps to turn on at anytime. The maps vary in performance.
Example:
1. Stock MAP
2. MAP A - 15PSI
3. MAP B - 19PSI
4. MAP C - 22PSI
You may not want to run MAP C without race gas or Meth spray as you will more than likely see detonation and timing being pulled.
  #441
Old 06-13-2014, 10:45 AM
Go-Cart's Avatar
Go-Cart
Go-Cart is offline
Map c
Example:
1. Stock MAP
2. MAP A - 15PSI
3. MAP B - 19PSI
4. MAP C - 22PSI
Ok so I think I understand how it works. So with the SPS switch I can either go from my stage 2 tune back to stock, or I can change the target boost level with the "maps a,b,c on the sps switch. But the SPS switch does not allow you to go from a stage 2 to a stage 1. It will only allow you to go from stage 2 to stock or change the target boost level with maps a,b, or c. Is that correct?
  #442
Old 06-13-2014, 10:54 AM
CPap's Avatar
CPap
CPap is offline
Correct!
  #443
Old 06-14-2014, 10:52 PM
johntotah94
It does not. I think its aimed towards VW/Audi. We don't have that setup in our ECU
  #444
Old 06-14-2014, 10:55 PM
johntotah94
I saw 258whp on a JCW Turbo that Nick tuned
  #445
Old 06-14-2014, 11:04 PM
johntotah94
Instead on an Accessport type setup, Powergate, or other map loader device that has to write your ECU every time you switch a map. 4 Maps are actually loaded onto your ECU when you get tuned by Manic. You have your original Stock Map, Map A, Map B, and Map C. What the switch does is you plug it in to the OBDII port with a map selected on the device and it will tell the ECU to switch to the map that you desire. It literally takes 1 second to switch performance maps. Plug the device in, hear a beep (finished), and remove device. You can do all this while you are driving also. I like to show people the power on the stock map (189whp 213wtq) and while I am driving switch to Performance Map B (215whp 241wtq) and then go to Performance Map C (Predicted 225+whp 260-280wtq).
It is amazing to see what 1 second can do to transform your car!!
  #446
Old 06-15-2014, 07:40 AM
CPap's Avatar
CPap
CPap is offline
Yes, as confirmed by nick. Would be pretty sweet to activate the anti-theft function.
  #447
Old 06-25-2014, 07:29 AM
Go-Cart's Avatar
Go-Cart
Go-Cart is offline
Have some Dyno results on the new Manic Stage 2 Tune on Map C with the SPS switch. Was done on a Dyno Jet with almost 90 degree temps. May have to swap out the Akro downpipe for a catless one as it may be choking things off a bit. But the torque band feels incredible still.
243whp 261wtrq
http://www.youtube.com/watch?v=64juX_eE5FU
  #448
Old 06-25-2014, 07:49 AM
doug@frankenturbo's Avatar
doug@frankenturbo
doug@frankenturbo is offline
That's a good result, just what you should expect from the JCW turbocharger. Great torque onset, too.
  #449
Old 06-25-2014, 09:34 AM
johntotah94
Nice numbers!
You must love the torque!!
On JCW Turbo?
  #450
Old 06-25-2014, 09:43 AM
johntotah94
Post it on the dyno thread
Quick Reply: Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
