Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#551
any update from the SF Bay Area person that's supposed to be offering the tunes?
I emailed info@manicmini.com a while ago about a few things related to fuel, bolt-ons, but never heard back.
#552
It's not per map, It's is a 3 step process.
Step 1 is to update the DME to the most recent factory software.~30 minutes on N18. ~15 minutes on N14
(helps keep dealer from flashing over tune since the factory tool will not overwrite anything that is up to date)
Step 2 is the "unlock" flash which allows switchable code . Same time windows.
Step 3 loads all performance maps at once. Same time windows.
#553
Now I really am going to dig in to reading this whole thread.
#557
#560
#562
#563
Will get the K04 as soon as I sell my JCW Turbo.
#567
Just spoke with Nick. He advised me that the "boost cut" on our vehicles can be defeated. It is not hardware limitations, like everyone thinks it is, but only software. He says it's an easy fix. Currently he is running 1.6-1.7bar on a N14 MCS no problem. N18 is a little different but they are running 1.6bar on that one. For the record, his company did crack our "impossible, military grade encryption, self generating password" (as members said) MEVD 17.2.2 ECU. So I kinda believe him when he says he can defeat the boost cut
#568
Realistic Expectation?
I apologize if this has been answered some where in 24 pages of this thread. Good thing there's no interest! Haha.
So...I have an '08 S nearing 100K and runs great. I have a JCW dealer installed tuning kit and a Helix intercooler and the usual piping cleanup done, stock S turbo. What tune level would be spec'd and what might the expectation be of performance improvements? Can anyone quesstimate an "is it worth it quotient"? Thanks.
#569
#570
The tuning kit gave between 9-18 HP, depending on who you talk to. A typical tune will get you between 20-40 HP, depending on how aggressive you go.
#571
I finally have time to have my Manic tunes files put on tomorrow morning. Received this info yesterday. You will have a stock mode and three performance modes. Mode A runs about 1.3 bar of boost. Mode B runs 1.4 bar of boost and little more timing, and Mode C (for this car) runs 1.5 bar and aggressive timing intended for 93 octane plus methanol on top, 500cc meth. You can a run a little less, but not you don't want to be too low.
1.3 = 18.5 PSI
1.4 = 21 PSI
1.5 = 22 PSI
Seems like a lot of boost, no?
1.3 = 18.5 PSI
1.4 = 21 PSI
1.5 = 22 PSI
#572
I finally have time to have my Manic tunes files put on tomorrow morning. Received this info yesterday. You will have a stock mode and three performance modes. Mode A runs about 1.3 bar of boost. Mode B runs 1.4 bar of boost and little more timing, and Mode C (for this car) runs 1.5 bar and aggressive timing intended for 93 octane plus methanol on top, 500cc meth. You can a run a little less, but not you don't want to be too low. 1.3 = 18.5 PSI 1.4 = 21 PSI 1.5 = 22 PSI Seems like a lot of boost, no?
#573
1.3 = 18.5 PSI
1.4 = 21 PSI
1.5 = 22 PSI
1.3 = 18.5 PSI
1.4 = 21 PSI
1.5 = 22 PSI
EDIT: Here's a compressor map that I got from Frankenturbos website. So at 22psi, your pressure ratio is 2.5, now I wonder what your flow rate is? Assuming a VE of 90% then I'm getting 26 lb/min at 6000 rpm. That puts you pretty far out there on the map.
#575
Hopefully someone will double check my work. I'm not an expert by any means on this subject.
But assuming that it is correct, then you definitely need to have a larger intercooler and meth to combat the heat generated, which you do have both.
Now I'm curious to see your IAT temperatures for the C map with the meth spraying full blast.
