Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#1151
#1152
Why are you on stock anyways, stock is boring
mQuebed Manic Tuning Dealer
#1154
#1155
on
If you do end up needing to replace your DV, I recommend adding the Alta Spring, best $17 Mod yet
#1157
Purely guessing here but if it really is a boost leak error then maybe it only happens when you're pushing higher boost, hence why you don't see it on the stock map. Symptom of a coupling tight but not tight enough. Check all you couples, etc.
#1158
Thanks!! Been reading through those as well. I initially thought it might have been the meth jet adapter. Resealed that and no resolve. The only clamps I have not checked are the 2 that go onto the intercooler. I am going to check those today.
Funny part is the CELT only comes on while cruising on the highway and I give it has to pass someone. That is the only time I get it.
#1160
#1162
#1164
Nice! So nice it switches maps so fast
#1166
#1167
#1169
#1170
#1171
About 130-160F IAT avg on full boost full throttle on a semi oval track at 20+ mins per session.
#1172
I glanced down real quick at Fontana... I think I saw 180+ F at peak. I was also overheating... more concerned about oil and water temps. Figure hot IAT was ok since A/F was in check. About 130-160F IAT avg on full boost full throttle on a semi oval track at 20+ mins per session.
#1174
#1175
