Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#1201
Clear your PM's I can't message, you are too popular
Do I need a boost tap (like NM) for the HFS-3, or just have it trigger off IDC? How is yours connected? I'm happy to have moved up from my $300 meth kit![Smilie](https://www.northamericanmotoring.com/forums/images/smilies/smile.gif)
mQuebed Manic Tuning Dealer
#1202
I am awaiting this as well as I think the direct port injection using the spacer would be an ideal balance between lowering temps and lowering carbon build-up.
#1203
#1204
No boost tap needed. It's all electronic, you tap into the DME to get the signals for boost and fuel injectors.
#1206
#1207
just got a P0597 for thermostat on the way in to work this morning... Wondering if it's related to the thermostat being open earlier or if it has nothing at all to do with the tune.
Already had the thermostat housing done under warranty not that long ago.
I will put it back to stock map on the way home and see what's up. No loss of power or anything funky at all otherwise. Drives fine, been in 2.5 + Map A forever, still haven't moved to B.
#1208
Cool. Was pretty sure you'd be using the right one. For others that don't know there are two other PID's for MAF in Dashcommand however they are based on speed/density calculations and not as accurate as a direct MAF reading. If for some reason you can't read SAE.MAF I'd try CALC.MAF.B as it compensates for inlet air temp.
#1209
If replaced less than 2 years ago I would be calling the dealer to see if they will take care of it. They have recently changed their parts warranties but they used to warranty any part replaced under warranty for 2 years so if you had a part replace right before it you went out of warranty they would give you a warranty on that part for 2 years from repair date.
#1210
#1212
installing dp this weekend, so I'll pretty much be ready for stage 2 tune, right? upgrades include FMIC, aem CAI, alta BOV spring upgrade, Invidia q300 dp back exhaust, and CNT catted downpipe.
another question, if I do further upgrades, such as hot side boost tube, would I need the manic tune upgraded to compensate for the change? probably no major changes like meth or anything. maybe just cabin noise delete, that intake cat delete thing next to the turbo, or hot side boost tube.
#1214
... if I do further upgrades, such as hot side boost tube, would I need the manic tune upgraded to compensate for the change? probably no major changes like meth or anything. maybe just cabin noise delete, that intake cat delete thing next to the turbo, or hot side boost tube.
#1216
installing dp this weekend, so I'll pretty much be ready for stage 2 tune, right? upgrades include FMIC, aem CAI, alta BOV spring upgrade, Invidia q300 dp back exhaust, and CNT catted downpipe. another question, if I do further upgrades, such as hot side boost tube, would I need the manic tune upgraded to compensate for the change? probably no major changes like meth or anything. maybe just cabin noise delete, that intake cat delete thing next to the turbo, or hot side boost tube.
#1217
on
Had to pull this question to the top due to the fact that I'm looking to run this set up soon as it's available. Im thinking go with a 5 way split: 4-direct port, and 1-to the IC tube. Only issues I would worry about is whether my pump can keep up. And than the obvious fact of needing a larger tank. What do you all think???
#1218
I had no MAF reading at all with my last tune. Now that I'm Manic tuned I do get a MAF reading however I haven't looked to see which PID is being used.
#1219
#1220
Got my stage2 tune done just leaving now. The guys at redline speedworx in NJ were awesome very professional. They charge an additional $100 install fee but I was able to drive there and get it done. So far I'm very happy with the tune but I've only driven 5 miles or so.
That's crappy they charge an install fee. There install fee is technically part of the price of the tune.
#1221
I said none of the other dealers charge a fee but they weren't gonna move on it so it is what it is. It was gonna cost more the the fee to ship the ECU and I wouldn't have my car for 3-5 days. It was worth every penny this tune is amazing it completely changed the way the car feels. The throttle is much more precise and power delivery is smoother. It pulls all the way through I had it at 140 tonight and it felt like it had more. The guys were nice at redline and they know they're stuff. There were only performance cars in the lot. A lot of S4s an RSTT a prowler and R32 and more. You could eat off the shop floor and they are very knowledgeable. I definitely recommend these guys
#1222
Is this PID something we have to search and hope is there when dash command is hooked up or can we type in the PID to use it? I had no MAF reading at all with my last tune. Now that I'm Manic tuned I do get a MAF reading however I haven't looked to see which PID is being used.
#1223
+1,
Using meth to affect intake air temp/timing is more of a trick to get more out of the factory timing maps.
#1224
Very true as far as it goes. However... Intake air temperature most definitely makes a difference in performance and how hard your turbo has to work. If your going to make 300BHP you need to feed 31 lbs/min of air into the engine. Air density changes with temperature. At 20 psi of boost 120°F air has a density of 0.162 lbs per cubic foot so that 31 lbs of air would occupy 191 cubic feet. If we drop the air temp to 80°F that density increases to 0.174 lb per cubic foot at 20 psi and the 31 lbs of air only occupies 178 cubic feet. That 40° degree split will result in your turbo having to work 13.7% harder to force the same amount of air into the engine and if the turbo can't push more air performance will suffer. In addition higher intake temperature increases flame speed and the tendency for detonation. That is why the factory tune pulls timing when intake temps climb over 110°. With meth or race gas the flame speed is reduced and you can run more aggressive timing but the temperature rule still applies. Cooler IS better.
#1225
so its been two or three weeks know since i went to eurotechsaz..... first off i would like to say i couldnt be more please with the service that jerry and "the dad" provided.....
second the stage 2+ manic tune and the direct port meth kit goes hard as fukkk
i mostly just drive my car in the b map and still getclose to 30 mpg in los angeles traffic
i also filled my car up 100 octane and my mini got straight ignorant every one turned their head... sport mode on it still back fires and farts like crazy
i also had some kid in daddys new carrera attemot to run me the mini walked it after 65 and had about two lengths on it.... i also got it above 140 on the marina hwy so i must say i enjoy my car alot and dont plan on getting rid of it any time soon ..... next step much needed susspension work and a much needed owens turbo
