Drivetrain Manic Motorsport brings us N18 owners OBD II Tuning! Solution is finally here!
#1551
#1553
#1554
Nice! Thanks! I have a garage too with heat - but it's filled with too much "junk" to fit my mini and close the door.
#1555
#1557
#1561
mQubed Motorsport, Manic Tuning Dealer
#1564
All of them are very close to the same IAT's and pressure drop mQubed Motorsport, Manic Tuning Dealer
#1565
If you have time to wait, another option is the new version of Helix's intercooler that is being tested before production begins.
#1566
That goes along with my liking to snow ski...
Until gps phone apps came along I never would have guessed that it is really easy to break 50 mph on a pair of skis while recreational skiing...
Between that and tracking my MINI, my fate has been sealed as both nuts and certifiable...
BTW - the really certifiables around here go ice racing when it gets really cold... Right now it has warmed up to 6*. I bet the ponds are well frozen now...
#1568
There is an entire section on this methanol does not add power but by keep tempatures cooler you won't lose any power to heat as well as the added benefit of keeping things a little cleaner inside
#1569
Methanol injection can add power if the car is "tuned" for it. Due to methanol increasing the octane rating of the fuel the tune could call for more boost and timing advance without increasing knock (hopefully). Map C on the 2+ requires race gas or meth injection.
A lot of people use methanol but don't run tunes requiring it. It's a safety measure.
#1571
#1572
Stage 2+, like all Manic tunes, comes with 3 performance maps: A, B and C, with Map C being the most aggressive. I believe that only Map C requires race gas or meth injection your choice. You should be able to run Map A and B without it. But double check with your Manic dealer.
Meth injection is a wonderful thing. It is a great "insurance policy" for your engine even on the less aggressive tunes. I'd highly recommend it.
#1573
on
As most have posted thoughout this thread, either Meth or Race Gas. However you do get three Maps A-C.
I am running Map A with no Meth on 93 octane fuel. I can do that because of my Mods listed in my sig. Mainly the FMIC which keeps my IATs low.
I'm waiting for my new tank to run MAPs B & C. Technically B is not mapped for Meth, but I'm not comfortable with the increase temps when hitting 20ish PSI. Map C will allow for 22.5 PSI only with race gas or Meth. Failure to provide that level octane and decreased temps could result in a catastrophic end state.
My point of view, only go for Stage II plus if you are planning to run meth or have easy access and can afford race fuel. Not worth the risk.
#1574
Just bought a Forge FMIC! Only a few days until it gets here from Southern California to South Florida.
Question to anyone who is knowledgeable about the Manic tune: Is it possible to code out CELs from a primary cat delete (I don't have my secondary cat) and bulb/light out warnings?
#1575
on
